181 - 195 of 195 Posts
Mine is a 2012 650 and I was able to eliminate buffeting and my head is in mostly still air.
Changed mirrors to the tear drop shaped Ducati? Test drop shaped Mirrors...eliminated 50% of buffeting.
added a parabellum tall windscreen topped with an MRA X Creen wing.... eliminated the remaining buffeting and wind hitting my on the sides/top of my helmet.
made the bike 200% more enjoyable on the highway and longer trips.
Its been years since I made any of these and I not sure if I have the original drawing any longer. If you download the pic you can then increase its size to help make out the dimensions.
I did download the picture but could not read the writing. Maybe you can make out you writing.
Top dimension (angle) - 3-3/4"
Middle dimension (overall length) - 3-1/4"
Bottom dimension (angle) - 2-1/2"
Up/down dimension (radius bisected) - 2-3/8" up and 2-3/8" down
The small end where it bolts to teh bike is - 1-1/4"
Hi all,
re bad Helmet buffeting ….
This is my 1st post, so hopefully it works...
In Dec last year, 2019, I bought a 2016 V Strom 650.
Abosolutly love the bike BUT as with so many others, the wind buffeting my helmet was really bad. Anything over 80kmh wasn't good.
After reading many threads from many sites, i decided to see what i could do about it.
- Firstly I bought the Givi Airflow screen to replace the original. I tried the Givi adjustable screen at different heights. I tried the main fixed screen at the 3 different height settings where it mounts to the bike.
It helped a lot with keeping the wind off me and was a lot quieter. It did stop a little of the buffeting but not a lot. Was great to ride with visor open though.
- 2nd I replaced the stock mirrors with the Aprilia type from Ebay. It was a little quieter but didn't do anything to resolve helmet buffeting at all. I even took the mirrors off completely just to try out, didn't make any difference for me.
-3rd - i tried a different helmet. I have a shark Skawl 2 and tried my sons MT Thunder 3 ... the MT was actually smoother but still getting buffeting.
- 4th. I read about the Augustus wind deflectors. So i made a set up but instead of the Augustus design, i went with this pattern and design that Cineris had put up in post #153.
It helped heaps. I was very surprised how much it worked.
It still wasn't a 100% but it was certainly so much better. # So to me , the issue must be in this area mostly.
Next step. I took those "winglets" off, re-heated them with heat gun to re-mould but now rather than just being on a slight angle, which deflects air around, i made them at 90 degrees to the bike.
So rather than deflect air AROUND the deflector on an angle, it was pushing air DOWN and OUT from the bike completely.
Took bike for a ride, even better again !. So this area is the issue for sure.
So next, i added a bit to the original design so that the winglet was longer. Took more air away from further up, re-made a set of the new version tried again.
Wow, - 100% ! I have no helmet buffeting at all, even at 130km/h. ( i even tried my Shark helmet again and was still ok )
To Do :
I went to BCF, ( a boating accessories place) and bought the black plastic box that the starting battery goes into , ie sturdy black plastic that can withstand the elements,
yet am able to easily cut with tin snips and mould using a heat gun.
I cut the battery box up and then traced the design onto it. Made 2 exactly the same and using tin snips cut them out.
Used a file and smoothed up some rough edges etc.
I drilled the holes where the mounting bolt goes through. (still used the original mounting bolt, no need for longer bolt)
I did fit a small rubber 'O' ring washer with the mounting bolt, between the winglet and the bike fairing, just stops plastic to plastic contact.
Made sure the winglet fitted ok and i could easily bolt on.
Took off again and laid it on a piece of timber.
I got the heat gun out, gently and evenly, heated the 'entire' winglet, not too hot or the plastic will start to blister but hot enough that the plastic was malleable.
Once really hot, with gloves on, i attached to the bike with the rubber o ring spacer installed.
Once fitted to bike in correct position, i then moulded, bent out the soft malleable plastic wing section, 90 degrees out, whilst pushing in firmly against the bike so it moulded into shape against the bike.
I then got my girlfriend to use her hair dryer on cold setting and start cooling the deflector whilst i held it in position.
When sufficiently cooled to hold the shape, i removed , put under cold water.
Then attached to the bike. The bonus is, if u get it wrong, simply re heat and do it again.
Once completed, u can remove it, u can trim with the snips, or a file it and just get it exactly right, easy to work with.
Being black, can hardly even notice it on the bike.
So u need a battery box / good pair Wiss type tin snips / heat gun / hair dryer with cool function / a rubber o ring / bastard file / a drill with suitable drill bit / good leather gloves... thats it
I have attached pics showing -
- original winglet design, on a slight angle where the air is deflected " around " it .
- a pic showing where i re heated the original design and then made it 90 degrees, so air was pushed DOWN and AWAY..
- a pic showing the new improved version, ie longer version, 90 degrees out and how it deflects the air DOWN and AWAY from the bike.
- also a pic showing the pattern i used and a measurements so if you print out and it doesn't print to size, you can expand or shrink until u get same measurements.
Its easy to do, cost is a battery box....
Hopefully this shared info will help others out there enjoy their V strom even more.
cheers Rod ps Im 5' 9" and this was all about helmet buffeting . I still get general buffeting but that's life with a screen...
Thank you For all the info helped a lot going to try it soon
So what is the HUGEST windscreen for this thing? I have a PUIG but I got the dark smoke and I should have got a clear one instead.
I'm getting old and don't want a gold wing yet. Hearing loss stinks. :(
If I wanted to black it out, tape it from the inside to maybe half way up instead of light smoke etc...
Hi all,
To Do :
lol
Hi all,
To Do :
Thank you for all the info will try it soon
Hi all,
To Do :
Thank you for the info. Will try it soon
About 3mm
Yes absolutely - riding is now a totally different experience, even with the makeshift idea-in-the-making the effect is very noticeable. The air around the front of my torso is still and the buffeting is stopped. The noise 'booming' in my helmet is greatly reduced (completely eliminated with my Sparx Octane helmet, not entirely with my Shark flip face, but my hand-guards appear to be the main culprit now) and I can move the GIVI AF3101 to different heights to match differing speeds (traffic, outrides, etc.) and/or I'm using my gel seat pad so sitting a little higher up, etc. etc.
I can hear the bike now - which is awesome! :mrgreen:
Thanks so much for this excellent post. I've been thinking about how to fix the buffeting.
Where do you mount the deflector?
I had some plastic laying around and thought I'd jump on the deflector train.
I can report that there is a noticeable improvement. It's not creating some kind of Goldwing style ride or anything, but compared to before, I certainly think it's a step in the right direction.
Makes me want to play with other shapes and maybe even try some deflectors down my my knees, mounted on the crash bars. I have seen riders exploring the idea that buffeting may be related (in part) to air coming up from below meeting up with air coming from above (over the windscreen)
You will also notice an after market "Beak" and I am wondering if that has actually helped a bit. Unfortunately I have not done an isolated experiment. I have not been at freeway speeds with one addition on and then the other. But last time I was going fast (with the side deflectors & the beak), I could swear things up near my helmet seemed better! I'm 6' 3"
Hi all,
To Do :
I just got a 2016 Wee and have purchased a Givi Airstream, and am intrigued by your deflectors. They look like they would work well.
We're 5 years past your post date - have you continued to use these and be happy with them? Any issues?
