21 - 30 of 30 Posts
Discussion starter · #21 ·
Update: I charged the battery, reinstalled. No error codes in dealer mode. The bike cranks (still no start). Pulled the tank and top sparkplug to check if its igniting. Consistent spark noted when cranking engine with starter. fuel supply related issue...? I did a thorough visual inspection of the wiring and connections (nothing visually evident of loose or bad wiring). Fuses all look okay. Next step, I will test the fuel pump relay... if good, I will check power at Fuel pump. suggestions??
@thadscottmoore, FWIW, you can leave your bike in dealer mode until you are happy that everything is working or you can ride it indealer mode to see whether any further / other dealer mode codes are displayed.
Have you sorted the C23 code that you reported in reply #19? Until this TOS code is sorted, your bike will start and cut out within seconds each time try you try starting the bike. https://www.stromtrooper.com/threads/tip-over-sensor.30361/ and https://www.stromtrooper.com/threads/by-passing-bank-angle-sensor-tip-over-sensor.6468/ are worth a look
Glad you found the issue. ✔
You said this occurred a couple of days after filling the tank. A fuel station to avoid from now on?
Glad you figured it out. It might not hurt to add some HEET to grab any lingering moisture in the far recesses of the tank.
In addition to the tank seal, be sure to check that the drain hole is clear. You can blast that out with parts cleaner to be sure. If you park under trees normally, suggest moving the bike out from under them.
Discussion starter · #29 ·
I did add Heet to it. Changed oil/ filter, pulled the fuel pump- cleaned the filter. Thank you for the input. I just purchased a waterproof bike cover. Its normally parked in a parking lot with no overhead cover.
2014 650 V Strom: I've had that problem twice. 230 KLX once. Friend with Yamaha Tenere once. We think it is ethanol gas collecting water after sitting 3 or 4 weeks. We had to hold starter long enough to push water through injectors before starting. They ran fine after a few minutes of running. Try Stabil for ethanol gas if it will sit over a few days and it should help.
21 - 30 of 30 Posts
