One positive, we'd never get water in the oil cavity . One pump drives everything.That engine does not look like an air/oil cooled engine even though it appears to be. There are no cooling fins on the engine. It looks water cooled to me, wonder if they would end up replacing the DR200 with it in a couple years? Suzuki could use something in the category.
It's a saree guard.What's up with the skirt/rear wheel guard? It fugly as hell, only on one side, and I'm missing why it might be needed. Except maybe for the asian markets.
Otherwise, looks like an improvement of the 250. 368 pounds claimed dry. Needs cooling fins with brushed edges though. Engines need to look like engines IMO.
And a 350/400 cc version for the US roads.
I wonder if the RM-Z 450 motor would fit?
Just like a DR650, DRZ-250 etc keeps those clean ... you change the oil maybe?Wondering how to keep that heat exchanger clean,internally.Oil changes would e critical.
Weight savings,& fewer parts to maintain. My Honda atv,350 es had oil cooling assist.Air cooling fins
Just good sense.
Service interval for top-end rebuild is as little as 40 hours.Just watched a Honda CRF250R make 37 hp on the rear wheel dyno last night...![]()
Main difference vs DR650 is the temp is thermostatically controlled and adds a cooling fan and thus no need for fins on cylinder. Changing oil drains the fluid. If you let enough crud accumulate in the oil to contaminate the cooler you will have engine failure well before that becomes an issue.Just like a DR650, DRZ-250 etc keeps those clean ... you change the oil maybe?
My '03 GSX1100G had the oil cooling. Worked well.Suzuki did this with the early GS & gsxr designs. It's not alien tech and won't deliver otherworldly performance but it is solid engineering.
