With all the reports of headlight problems, I thought it would be a good idea to gather some information on how big the problem is.
Luckily, I found no evidence of heating/melting of the connector assembly on my 08 Wee when I finally got around to installing the Eastern Beaver Relay Kit at 23K miles. The EB kit does make the already outstanding Wee headlights noticeably brighter!
Thanks for the reply..when it happens there is no click from the relays..I'm pretty sure they aren't getting the signal to switch..because they click over just fine when the hi/lo switch is toggled..I checked the connector in the left fairing and it's perfectly fine..no scorch marks or any corrosion..maybe this weekend i'll remove the tank and airbox and look at the connector above the radiator..or maybe i'll just live with it..doesn't seem like too big of an issue..There are no stock relays. Is the relay clicking when you turn on the ignition though the headlights are still off? If so, you need to replace the relay. If not, the stock wiring may have became marginal before the relay kit was installed and that needs to be addressed though the relay may still be the culprit.
Did you try cleaning the contacts at the starter button and/or hi/low switch?running into the issue now where every now and then my headlights don't come on until I flick the hi/low switch..I have a relay kit installed..pushing the starter button again doesn't fix it so wondering if anyone has a fix or where I should start looking..it's not a huge deal but I like to fix things lol..is there a stock relay for the headlights? maybe it's getting tired..also will check the multi-connector in the fairing and see if I can locate anything..thanks
I've cleaned the starter button before cus it was having issues where you would have to press it again for the lights to work, but this has now been remedied and doesn't fix the issue I now have..I have not cleaned the hi/lo switch..couldn't see any documentation of it being cleaned so haven't opened it up yet..i'll start there though if that is a possibility..would beat taking the tank and airbox off lol..Did you try cleaning the contacts at the starter button and/or hi/low switch?
You being serious? LOLtotal headlight failure...connector on top left radiator shroud 2014 model....why does these fail
