ditto on the two fingers on the brake lever, started doing it when I got the wee,
just seemed natural.
Has anyone heard about the new Aprilia Shiver 750?
It has a ride by wire throttle. with 3 settings for power / throttle response.
How cool is that!!!!
From the Aprilia web site
The Ride-by-Wire system controls throttle openings by an electronic connection alone. This advanced and sophisticated system manages engine power in real time, adapting output to engine speed, road speed, gear selection, atmospheric pressure, throttle position and even the speed with which the twist-grip is being turned. This results in the optimal fuelling for any given riding situation and style.
Tri-Map Selectable Engine Mapping
The electronic engine management on the Shiver 750’s engine leads the field in technology and performance. The Shiver features a second generation electronic throttle with Tri-Map selectable triple mapping.
Three performance modes, Sport, Touring and Rain, can be selected on the move from a switch on the handlebars (with the throttle closed for safety reasons). The Shiver changes its character radically, depending on what mode you select. Sport mode gives you aggressive instant power; Touring mode gives you smoother throttle action, better suited to relaxed long distance riding; and Rain mode provides reduced power for improved safety on slippery surfaces.
The Tri-Map electronic throttle also means smoother, more consistent power thanks to more accurate and precise throttle control based on parameters including engine speed, gear selection, air flow, throttle position and temperature. The V twin engine performs superbly at low and medium revs and even at partial throttle openings, situations typical of the sort of riding the Shiver 750 is designed for.
