For the past month I have been trying to figure out why my throttle wont return to idle and I come to a stop. The RPMs hang at about 2500 even with the clutch pulled in then after a while it drops back to idle.
I have done the following so far
1 Adjusted the throttle cables as per the manual so this is not the issue
2 Lubricated the throttle body links
3 Cleaned up around the butterflies and they are not sticking
I took the bike to the dealer today to get them to take a look and $360 later I still have the problem as they couldnt find the cause.
Here is what they did
1 Re set TPS / STPS STVA Fast Idle system.
2 The mechanic suggested it might be the fuel pump but I replaced this last year with an OEM pump.
Hoping some one on this forum may of had some experience with with this issue or some advice on what to check.
Thanks in advance
Thanks in advance
