This post pertains to the stock voltage regulator and the series regulators that the aftermarket provides. My understanding of electrical systems isn't fantastic but I have some basic understanding.
Right now my bike, which is electrically stock except for a power commander and lithium ion battery, makes great voltage at idle while hot (14.7V at battery). There are no problems with anything electrical on the bike that I know of, but that number does seem a bit high to me. Please chime in if you have thoughts on this part. When bike was purchased seller said they had the stator replaced, I'm assuming a factory one but I don't really know. The voltage stayed steady through different rpms.
I want to switch my headlamps out for LED for brightness, but became concerned as shunt regulators/rectifiers return any unused amperage as heat to the system. With my system seemingly working well right now, I was concerned that switching to LED lamps might have an adverse effect maybe even potentially cooking the stator.
Is this a legitimate concern? In the future I plan on installing a voltage guage, phone charger, and heated grips (which will seldom be used). None of these draws a lot of current, so that wouldn't really 'help' if I was trying to better match the factory electrical draw.
I'm not sure if it's easy/worth it to change to a series rectifier/regulator, but my understanding is that they only provide the amperage that the system requires. Is that correct, and is it worth doing? Easy?
