Sale On McCruise Cruise Control
13K views 53 replies 23 participants last post by  Motor7
#1 ·
They are having a 21st Birthday sale and have marked 15% or greater off their products .
I can vouch for how good this system works , just like a car - cruise is easy to set & switches off if gear changed , brakes applied or deactivated by pushing a button on the handle bar controller .
The LED handle bar unit glows in the dark and if your mechanically minded is pretty easy to install . I had it done by a bike shop
Reactions: 68hoosier
#2 ·
Thanks for the heads-up. For folks in the USA, that brings the price down to just under $700. While that is still a large chunk of change, I think it's worth considering.
I had the system on a previous bike, and it worked flawlessly.
I'm thinking very seriously about taking the plunge.
#9 ·
Just find the instructions for the Rostra setup. The 250-1223 electronic unit and the control pad, not the stalk. I added it to my 08 650 and it made my 2600 mile trip out west last year possible with a right wrist still sore from a previous injury. Just need good instructions which are one the net all over the place, some clear silicone to waterproof the control pad and basic tools. Just be ready to either wrap up a lot of extra wire or clip out long lengths of excess, since it's really designed for a car. The main unit fits snugly turned on it's side in the void behind my seat.
Sent from my SAMSUNG-SM-G891A using Tapatalk
#10 ·
Seems the asking price of the MC Cruise stuff gives people a bit of heartburn.
In my very humble opinion, the determination of whether or not something is "worth it" is the sole responsibility of the person considering shelling out their own hard-earned money to purchase the aforementioned something.
In my case, I've had an MC Cruise system on a previous bike. I've also used a bunch of different throttle locks (and crampbusters for that matter). As far as I am concerned, the MC Cruise system is "worth it". Why? It was designed from the ground up to be used on a motorcycle, installs with minimal fuss (or so I'm told), and it works well (which I know to be a fact).
#13 ·
Darn it! I should have waited a bit. I just bought mine a few months ago and it's already installed on my 2013 650.
I can verify that it does work very well, and when I did have a problem installing it (my mistake), the e-mail and phone support from them solved the problem. It was a lengthy installation (for me - not a mechanic) that went "almost" perfectly because the instructions are very well done. In my installation I had pinched the throttle cable in the assembly but I couldn't tell by looking at it.
For those purchasing a unit; there is also a $90 fee for DHL Express and $21.00 import duty charged in addition.
I am very happy with this addition and I'm looking towards many long trips this summer.
Keith
#15 ·
I didn’t realize shipping was that much. Also, I was under the impression that “motorcycle accessories” weren’t subject to duty charges. That was the case when I ordered stuff from Italy anyway.
#16 ·
If you take an old "O" ring off an oil filter, cut once an zip tie it between the throttle bar housing and place between the rubber throttle grip, wala el cheapo cruise control. Practice makes perfect. Gives the wrist a break for awhile, just not automatic, remember to release after the wrist break.?
#18 ·
I don't use my MC Cruise control to give my hand a rest I use it to keep the cops off my back.
Bikes pick up speed and drop off speed much quicker than a car.
Set & forget, I never need to look at the speedo again until the road conditions change.
#20 ·
I miss the days of buying a Audiovox CC-100 cruise control for around $100 at auto parts stores. I have one on the ST1300 and probably should remove it, before I sell the bike. I'll never find another at that price. They quit selling them when cruise control became an almost standard accessory on autos.
#23 · (Edited)
#26 ·
The CCS-100 was a little easier to install because the servo and vacuum reservoir were in two pieces and each were smaller than the Rostra. The CCS-100 was better in response to accelerate and decelerate signals in 1mph increments whereas the Rostra seemed to need the button to be held down longer so it either wouldn't respond or would change by 3-5mph. The Rostra was easier to initially set to a speed over 65mph. The CCS-100 liked to bleed speed down to 70mph if set above 70.
#35 ·
I can't speak about size vs ccs100, but the Rostra servo box for snugly in the void behind my seat when turned sideways. So much so that I didn't need anything else to secure it, just stuff a tool roll next to it. As for the sensitivity I don't have the issues you experienced, save for the set time. I got used to holding set for a couple seconds till I felt the servo take up the slack. The one thing I do not like is going downhill when going under say 65mph. The reason is the the bike accelerates to quickly in that situation for the servo to react. So you slow down to the point it decides to speed you up then it shoots past the high end and it starts to slow down again. When going faster the wind resistance prevents the bike from accellerating too fast and the servo can manage it, most of the time. Otherwise for about $200 and a weekends swearing during install it works well.
#41 ·
I use it all the time . Its become second nature just the push of a button its that easy . Come a hill or slight increase in elevation the bike just responds .
I wouldn't buy another bike without it or the ability to have it fitted to that bike if I so decided , because its that good .
Took a GSX1400 for a demo & fell in love with it . Beautiful riding postion , real comfy seat , sharp brakes , good distance on a tank of gas , tons of grunt but McCruise specifys the upgrade kit needs to be bought in conjunction with the cruise kit . Messy
On the V-Strom models the cruise control comes with a compact electro servo meaning the master unit is compact & tidy .
I'll try & take photos when I get a chance
#45 ·
After playing around with cropping photos this is what my McCruise looks like
#49 ·
Hi keithert if you look on McCruise Cruise Control homepage under Suzuki V-Strom 650's there's a couple of photos .
The part that pulls the throttle is under the front fairing called the electric throttle servo
