OEM handguards
1 reading
1.1K views 4 replies 4 participants last post by  more horses
#1 ·
Wondering if someone can help. I bought a bunch of accessories for my new wee Strom including Suzuki oem handguards. I went to install them today but I must have lost the installation instructions. If anyone has a way to scanot them and post here it would be great.
Greg
#3 ·
I just installed them yesterday, can’t scan the instructions though.
first, remove the bar end weights. Do not turn those screws out more than 2-3 turns, then use your strength to pull the whole assembly out. Replace the screw with those in a new set, also another thick washer instead of this rubber thingy which you do not need any more, screw the end piece to it and insert back to the bar ends, do not tighten.
Then you need to remove the rubber cover of the cluch lever, for that undo the cluch lever, install a shorter cover from the new set.
then screw out the pivot bolts holding the clutch and brake levers in place, toss them and replace with the new ones in the set. They look similar, just longer.
Now install the covers so that they fit between the bar end weights and the lever pivot bolts, then tighten everything.
hope you got it. Sorry for my clumzy storytelling skills.
