I had posted in another thread before, but it appears that bad gad wasn't the problem.
My bike occasionally sputters and bogs down. I was like I had water in the tank. Today I pulled the tank and fuel pump to drain. It came out perfectly clear gasoline with no water or flecks of solids. Just gas.
But the bike had the problem before I parked it on Wednesday. Maybe the fuel injector has a problem? I've run more than a can of sea foam through over several tanks. Should I try another product?
Maybe it's the pump? Except the intermittency I could think that. The pump wouldn't misbehave badly unless it had electrical problems.
Electricity: the battery (+) had lots of corrosion on it. The battery tests out fine, but it hesitated while starting. I had to push start is on Wednesday. Some jackass let the air out of my rear tire, and I had to inflate it with the slime pump. This drained the battery of course. Would corrosion and possible weak battery cause the fuel pump to work only 85% of the time?
Air filter and spark plugs are all less than 4 months old, and this problem existed before changing the plugs and filter.
I'm at a loss. Any help is appreciated.
