Hi folks:
Writing to you from the town of Palenque Mexico.
I did a lot of research and decided to go with a Pipercross cleanable air filter. I thought, given how annoying it is to find any parts in Mexico that I would make my life a *bit* easier by finding a re-usable air filter that I can use and clean.
I also bought a No Toil Air filter cleaner kit as well. I then installed it correctly (the finer foam - (red side) down) with the included rim grease.
I swapped out the air filter a few hundred miles ago and threw the stock filter away... because the Pipercross one would be *so much better* right?
So now I'm riding and I feel a noticeable loss in power and torque. I would put the stock filter back in but I threw it away.
My thoughts are:
1) The simplest solution is almost always right. Have a replacement stock filter shipped to me in Mexico.
2) There could be some other problem that I'm noticing at the same time. I.e. transmission, clutch etc. But I'm guessing its the air filter.
Your thoughts?
[I will never throw anything away that I can use as a spare in the future :headbang:]
My thoughts are:
Your thoughts?
