EarFuze custom earplugs
7.7K views 6 replies 5 participants last post by  Heavy
#1 ·
The basic review:
Pros:
Cheap, even for Canadian buyers (~$50)
Only 15 minutes to mold
Headphones included
Custom fit for your ear
Cons:
Headphone quality isn't the best
Sound is so-so
Wind noise protection slightly worse than foam
Performance depends greatly on bike and environment
The detailed review:
The EarFuze headphones make some pretty good marketing claims. Custom fit, cheap to buy, easy to do yourself, and ready to use for a variety of activities, including motorcycling. For the most part, they deliver. Your mileage will vary, however, depending on your motorcycle and the environment you ride in.
MOLD:
The mold process was dead easy. They offer a package that includes a practice mold for peace of mind. Many folks skip it because it is so easy to do. Insert earphone, mix 2 compounds fully, press into ear. Shape. Pull off excess. Sit around listening to music for 15 minutes. Done.
EARPHONES:
The 'phones aren't band, but they aren't great either. There is a good amount of clarity, and for the most part the sound is balanced well. Those hunting for 'phones that deliver good bass ought to look elsewhere...the bass delivery just doesn't cut the mustard. They don't sound thin, but 'full' isn't the word I'd use either. They are the in-ear type, so the delivery of sound is quite good. Audiophiles will be disappointed with the fidelity, casual users won't notice the difference. You will need to adjust your music source volume down if you have never used these before. This is a good thing, because you get to extend your battery life. The last note about these is that the build quality seems on the cheap side. Since they are going to be encased in the mold, this isn't the end of the world. However, a good tug on the cord looks like it might try and escape from the actual buds. I used extra mold material to fully encase the bud and connection to mitigate that.
TEST RIDE
Just so the results are balanced, here are the particulars of my test ride.
Bike: 2003 Kawasaki EX500 (sorry, the Strom is 1000km away) w/ Laminar Lip
Wind conditions: ~20 km/h gusting to 30
Helmet: Zox Supercomp R
Rider height : 6'2"
Area: Flat, wide open prairies.
Hearing: Good. I have a pilot's license.
With that out of the way, we can already see some issues arising. First, the Ninja 500 isn't exactly offering the most protection from the wind, even with a Laminar Lip. Second, while the wind isn't so bad, the prairies have a way of making riders miserable when there is wind about. It is always loud, no matter what you do. Third, the Zox helmet isn't known for being a quiet lid. If your gear or conditions are better, you will experience better results.
Below are the observations I made with regard to the clarity and relative volume of the sound from the earphones. iPod Shuffle volume was set to roughly 50%.
0-40 km/h - Virtually no difference in volume or clarity.
40-60 km/h - Slight loss in clarity, volume same.
60-80 km/h - Bigger loss in clarity, volume slightly decreased. Still very 'listenable'.
80-100 km/h - If you don't already know the song, following along will be difficult. Volume decreased.
100-120 km/h - Songs initially difficult to identify, even if well known. Barely audible above any wind gusts.
I can already tell you that if I were on my Strom, the speed values could all be bumped up by 20 km/h or more for the given notes.
If you like the nuances of your music or are otherwise a very picky listener, these won't really do it for you. If you just wanna listen to "Thunderstruck" while you tackle the twisties, this ought to work. If your bike or your riding environment tends to be very loud, you will likely have trouble hearing what you want.
For my purposes, I give them a 7.5/10. Excellent value for money, but I would have paid a little extra for better earphones.
Questions?
#2 · (Edited)
Great review! :thumbup:
I also tried the EarFuze kit, and was also quite disappointed by the poor noise isolation. The earphones are noticeably lower quality than most, and I can see where this would also be bothersome (if you could hear the music in the first place).
Where I want music would be on those long, boring highway cruises, and this is just where the EarFuzes disappoint. I prefer to attack twisties with regular ear plugs (no music), so that my attention is focused 100%. My Earfuze earphones also stopped working after about 10 uses. :thumbdown:
Another option I am planning to try is to get the putty and use this with the earphones of your choice. For example, Skull Candy or Marshmallow ear phones are easily available for around $15/20 a set and sound much better.
There are a few different sources for the putty to make your own custom ear plugs. Here's one:
http://earplugstore.stores.yahoo.net/radians-custom-molded-ear-plugs.html
Haven't had time to try this yet, but my thinking I'll do the same thing with higher-quality earphones, and then put my helmet on while the putty is setting.
The biggest weakness of the custom molded plugs is that they are a fixed shape, and I noticed that once I have my helmet on, they let a lot more sound in. I think the pressure of the helmet changes the shape of my ears just enough to let sound in, so perhaps wearing a helmet while the putty sets would address this.
There are also people who have made their own by inserting tubing into foam plugs to create a sound channel, and then gluing this to good-quality earphones. This is probably the best approach as far as isolation, but it's tedious -- if someone made disposable plugs with the sound channel and a way of locking them onto the earphones, I would buy 100 pairs.
#4 ·
I am to understand the sound quality isn't the best with the Fuze, but could you replace the stock phones with a better quality and still use the mold?
I use a set of good quality buds, but they fall out when I put the helmet on.
So basically can you mold a different set of buds in the mold, or do they have to be the ones that come with it?
my earbuds MDR-EX36V | EX Earbud Headphones | Sony | SonyStyle USA
Ice
#5 ·
Yes, you could easily replace the buds and mold around them instead. Make sure you are leaving enough room to get your helmet on. With the set you have linked, I would only form the mold around the outside of the units. where they contact the ear. Get the kit with the test mold and give it a quick try.
#7 ·
Don't bother with the upgraded buds. I've done it and the putty shrinks when it sets. You lose the great fit in your ear and the sound, even with the better buds, sucks. I have a set of custom molded ear plugs, with no buds, and they are 100% better at killing sound. The EarFuze putty just doesn't maintain the fit well enough to seal out the external noise.
I have an old set of Shure E2c ear phones and they kill the sound of the EarFuze setup, even with better buds and they block out more external noise too.
