Dealer mode DL1000 2003
1 reading
16K views 7 replies 4 participants last post by  Streetsquid72
#1 ·
Hello everyone, just bought a very nice 2003 DL1000 and new to this forum
I would like to know where the connector for the dealer mode is located.
I found next to the battery a tiny white six pole connector wit a cap on it.
Is this it?
I so, after removing the cap all pins are interconnected with a kind of bridge.
Should I remove this before connecting the two wires
Any help is appreciated.
A new V-strom rider
#2 ·
'03 and earlier DL1000's have four connections in the dealer mode connector. All 1000s put the connector under the left side painted cover near the ECU. Look for White/Red & Black/White wires that need to be jumpered.
#3 · (Edited)
Thanx
Hi Greywolf, thanks for the quick reply but I can't find the connector you mentioned. Only the small 6 pole that I mentioned before and a three pole connector that's connected. (With red black and green wires connected to it)
Also in the service manual I see the picture of a three pole connector with the dealer mode switch.
Could this be it?
Should it be disconnected before bridging the wires?
G
#4 ·
The connector you have found is a ground block. It has a plastic cap, a little metal bridge jumping all the pins together, and all the wires coming into are black/grey (IIRC). Removing the bridge thingy will just un-ground whatever is run to that block.
The connector you are looking for has a rubber cap and different colored wires coming into it.
They are in the same general area (left side back cover). Keep digging around in there and you should find it.
#5 ·
Found it !!!
Thank you all, I found it. It was way back behind the fairing, far behind the battery compartment, almost on top of the rear wheel. Guess they sometimes are a little generous with wire when making the harnesses.
:hurray:
Anyway, TPS OK and no fault codes
#6 ·
Dealer Mode? Color me lost...what are ya'll talking about and is it something I need to know about? If so, please educate me? :confused:
#7 ·
#8 · (Edited)
My Thanks to "grEywolf' for posting the link back in '06, to the VSRI group, which has excellent photos of the dealer mode connector. I was looking at the 6 pin connector with the plastic cover, which I now read to be a
grounding block. gotta go back on the hunt when i get home... Found it. Just as an extra note, the word "UP" is
unmistakeably, not sure if I spelled that correctly, molded into the rubber cover. All this to find out that my TPS is
properly set.
