Ive been fighting with the clutch in my 2008 vstrom with 73.000 miles that i just recently bought. the previous owner told me that he "messed up the clutch adjustment and replaced the clutch plates. the engadement point on the clutch changes after a long ride to the point where its almost immediate as i let go but when the bike is cold, its pretty far out. its also impossible to shift into neutral while the bike is hot and stopped. i adjusted both the freeplay and the adjustment screw per the service manual and if i turned the adjustment screw in till i felt resistance then backed out a quarter turn the bike would still move forward with the clutch lever fully engaged. i kept screwing it in past the point of resistance til it felt right but i had the same issue with the engagement point changing after the bike warms up.
I replaced the clutch cable and clutch actuator just to rule those things out but im having the same issues. any ideas?
also worth noting it seems like my adjustment screw at the actuator is screwed in much further than what ive seen on other bikes. almost all the way in. I did pull out the actuator rod and it seems to be in good shape
