Brake light stays on!?
4.1K views 5 replies 4 participants last post by  silverstrom
G
#1 ·
It has done it to me 3x now. Caught it the first 2xs but missed it this time and if one of the guys at work had not called me on my cell and told me about it it prolly would have killed the battery.
For some reason when I turn the switch off the tail light stays lit. To get it to go off all I do is turn the key to on and then back off and the tail light goes out. Another piece of info that might pertain is that U can operate the turn signals while this is going on also, the key is not on.?? Anyone else had this problem?
#3 ·
I bet that you are turning the switch to "P" before you remove the key. It's easy to do and "P" is for Park and means the tail light stays on and the hazards (indicators) work.
I suspect it's an owner issue not a mechanical one.
#5 ·
I have done that also, I turned the switch too far, just check the position of the switch or check your tailight before you go in.
