After clutch travails neutral light doesn't work?
2 reading
12 views 1 reply 2 participants last post by  ThruST
#1 ·
2021 dl650.
So I completely burnt my clutch trying to practice stop and goes. I learned exactly how much a clutch cannot take. I was being really mean to it.
In replacing the clutch I discovered that one plate is different than the others and goes on the inside with the shims inside it.
Proper new clutch operation restored I discovered that the neutral light and N doesn't appear any more.
Thoughts? Would something I did having it apart and back together a couple times cause the neutral sensor to go wonky?
- Skylos
#2 ·
2021 dl650.
- Skylos
Do a search about the neutral/gear switch. I recently read a thread on here that talked about the issue and about cleaning the switch. Apparently it's a common issue.
Start here
(1) gear indicator problem | StromTrooper https://share.google/B47Tf4ihZllZHpJZF
