2004 Vstrom 650 fuel preference. Plus, do you use Seafoam.
5.3K views 27 replies 22 participants last post by  TinMan88
#1 ·
Hi guys, I do apologize for the multiple threads. I really appreciate all the advice I have been given.
My '04 V is my first real street bike. I had my thumper DR650 for many years. The DR would happily run on anything.
I used regular gas, which in Canada is 87 octane.
Does the Vstom like higher octane fuel??
Its fuel injected, should I be adding Seafoam or any other cleaners? Does the fuel injection need any maintenance or cleaning?
Thanks in advance and happy riding. I have has the V for almost a month and am really liking the engine. Tonight was the first time I cracked open the throttle and hit the redline...very briefly of course. I wouldn't want to exceed the posted speed limit.
Cheers!!
#4 ·
Regular, occasional shot of fuel injector cleaner, generally before long rides so it isn't sitting in the tank for long.
The injector cleaner seems to do a fair job of cleaning the fuel filters. I have a spare pump that I brought when I first started having the classic fuel starvation symptoms, gave it some FI cleaner and the problems went away. Pump is still on the shelf as a result.
#5 ·
87 here too. I vaguely remember someone saying the bike runs better on 87 than on higher grades, not sure about this. This one thing I love about the Strom is that it's designed to run on 87, something that is becoming rare with motorcycles.
I have a gallon of Seafoam which I run in the lawn mower, snowblower, etc, I also run it through the Strom once or twice a year, not sure if it's helpful, but it doesn't seem to hurt. I use fuel stabilizer when I store the bike over the winter.
BTW, I flipped 97K miles yesterday and the bikes as smooth or smoother running than the day I bought it.
#9 · (Edited)
Top Tier fuels contain better detergent additive packages and assure that water is within "acceptable" limits, octane really is as advertised, etc. So it's Top Tier regular 87 blend for all the riding season. I'm getting 60-68 mpg as it is.
Since the 650 has a metal fuel tank it will get a tank or two of non-ethanol 91 before the six month winter lay over here also with a bit of two stroke oil and stabilizer additive.
Using premium non-ethanol 91 isn't worth it when the engine doesn't require it. It's $.60/gallon more expensive and the very minor (if any) mileage increase from the ethanol free benefit will never recoup the cost (unless you count the peace of mind factor).
#11 ·
87 octane here too with 75,000+ miles. Except for winter storage when I fill, as much as possible, with no ethanol gas (BP premium) and a dose Sta-Bil.
288517
#19 ·
Thanx for the info. I ride pretty conservatively too. (usually). My mileage was also calculated via old school method. Perhaps I need a cap full of Seafoam.
Captnjim: I’m with most other replies on here. In my vehicles I run the manufacturer’s recommended octane (everything I have is 87). My job takes me away from home for months at a time so, as others, I leave the bike and other engines / tanks filled with non-ethanol with a bit stabilizer.
#20 ·
Thanks all for the replies. 87 it is! Maybe I'll throw in a bit of seafoam. Can't hurt. Hit 10,000RPM briefly this week. Man, what a sound. But I do feel guilty, poor old bike,
Hopefully not too bad to do it once in a while? usually 2nd gear, just to get up to highway speeds. I never go over 120km/hr.
#25 ·
There is one aspect that no one mentioned. AV Gas. If you are going to store your bike I have found that AV gas is by far the best. It has super good detergents, lead, and 100 octane It will not go bad for extended periods. I have had vehicles it in storage for over a year and never had it go bad. It is one of the best fuels you can use as long as you don't have a catalytic converter. They don't want airplanes falling out of the sky because of bad gas. It is really good at cleaning injectors. You can usually find it a small air ports, petroleum distributers, etc. They will not pump it into your bike, you have to bring cans.
Just a little FYI Best regards, Tractormel
#21 ·
I always run regular unleaded, & no additives. On my 1st VStrom, I tried 91 octane for a while. Since I always track my mileage, it was easy to see that there was no MPG difference whatsoever, and I couldn't discern any performance difference.
Slowing down can certainly improve mileage greatly. Altitude also affects it. Living in Texas for many years, my bike got 48-50 mpg in general highway riding. In Colorado, riding under the same conditions, I'll get closer to 55. On back roads riding at 5K feet or higher, 58-60 mpg isn't uncommon, and I've hit 68 a couple of times.
#23 ·
FYI slightly improved mileage with non ethanol 91 vs 10% ethanol 87 is due to the ethanol and not the octane. V-strom doesn't need the octane and it will add more buildup in the top end. Storing with non ethanol is best. Occasionally run Berryman's B-12 to clean injectors. Not a seafoam believer.
#27 ·
I habitually use the CRIF fuels, 87 octane, no additives, 55 MPG, only at 44,000 miles on my 2007 Wee. I hardly ride it anymore. It recently sat for 8 months untouched except for battery charger, then fired right up two weeks ago. No issues.
(CRFI = Cheapest Crap I Find)
