Hello,
I just bought a 2008 DL1000 a month ago that had just under 8000 miles. It developed a small leak where the clutch push rod seal is.
My first two attempts ended in failure. Third time was a charm. First time I followed the advice of a sticky posted on here that recommended using a thin layer of food grade silicone grease ( like plumbing grease ) around the contacting surfaces of the seal. That was a bad idea. Second attempt failed because I tried to reuse the new seal again. Third attempt ... I made sure all the oil was drained completely so there was no oil pooling up behind the seal. I used alcohol, q-tips and a very clean rag to make sure everything was spotless. I decided to use Honda-bond 4. I put a thin layer around the outside edges of the seal, waited 24 hours. I than took a very small paint brush and applied a thin layer of the Honda-bond 4 around the outside edge of the seal and case, waited another 24 hours. I also decided to replaced the clutch rod. In the factory service manual Suzuki recommends using Suzuki Super grease, an inch on each end of the rod. ( A little lite weight type of grease is probably fine.) Success ! So far so good ! No sign of any leaks ! It's been about 50 miles with a couple of heat cycles, high revs and hard riding.
I literally called 10 Suzuki dealerships to get an opinion from various service departments. Each one had a different opinion about installing those push rod seals.
A couple dealers said do it dry, A couple dealers said use sealer, A couple dealers said use grease, One dealer said use contact cleaner to lube the seal, push it in and it will dissipate.
The Honda-bond 4 is very sticky and can be messy if not careful.
