What chain wax/lube do you PRIMARILY use?
  • DuPont (Teflon Chain-Saver)
    Votes: 158 27%
  • Maxima (Chain Wax)
    Votes: 124 21%
  • BelRay (SuperClean Chain Lube)
    Votes: 48 8.2%
  • Tirox (Chain Wax)
    Votes: 7 1.2%
  • Motul brand
    Votes: 58 9.9%
  • Ipone brand
    Votes: 4 1%
  • Wurth brand
    Votes: 18 3.1%
  • Motor oil (used/new?)
    Votes: 41 7%
  • WD40
    Votes: 19 3.3%
  • (other: please post and specify!)
    Votes: 107 18%
Chain wax/lube vs Chain Life, and reviews
132K views 459 replies 162 participants last post by  TinMan88
#1 · (Edited)
Hey folks,
Here's a fun little poll I posted on another forum, that might be of use to both new and experienced riders alike.
Wondering who's using what chain wax/lube product (yes there's tons of threads on this), but additionally, what kind of mileage you're getting out of your chains & sprockets, as well as your personal thoughts on the product you've chosen.
Can't make a multi-question poll, so here's what I'd like you guys to do:
  1. As per the poll options, indicate which wax/lube product you mostly use. If yours isn't listed, post it in a response; same goes if you've switched between different products. I'd also like to know whether you ride in all/most conditions (winter/salty roads, rain, dirt etc)
  2. Post a response with details: How frequently you lube, what (if any) cleaning product/method you use, and your personal thoughts/mini-review on said product.
  3. Post the mileage you've gotten out of your current or past chains. i.e. if a chain lasted 25k, 40k, etc before needing replacement, and how worn they were at that point. (this is the info I'm mostly looking for!)
  4. (added after initial post) What brand/kind of chain are you using? (D.I.D. VX, EK, RK, Renthal... 525/530.. etc)
Alright folks, let's hear your own responses!
#2 · (Edited)
My own answers -- Regarding the chain wax/lube:
  • I have used various products, but the main one for about the past 1.5-2 years has been DuPont Teflon Chain Saver. Prior to that I used Belray briefly, and Maxima Chain Wax for probably 2 years before that.
  • 2010 Ninja 250R had over 27,000km on it, pretty much entirely using Maxima Chain Wax, and the chain & sprockets were still in great condition when the bike was sold. Wax retains its waxy/lubricated feel, however, I find the Maxima wax can gunk up a lot, particularly inside the front sprocket cover.
  • Switched briefly from Maxima to Belray SuperClean Lube (the stuff that sprays on white) but felt despite its "anti-fling" claim, the stuff got all over everything and was a big pain to clean off. Switched back to Maxima for a while, until:
  • Started using the DuPont Teflon Chain-Saver product about 1.5-2 years ago, mostly due to popular recommendation. It's also nearly half the price of some of the products sold at dealerships for a similar capacity can. I find it goes on much cleaner and doesn't fling, but I have a hard time determining whether it's retaining the waxy/lubricated feeling after a few hundred KM, where other products clearly retained it.
Regarding the chain itself:
  • I ride in mostly all weather conditions; winter as long as there's not significant snow/ice on the roads, regardless of salt. Rain is no problem. I don't do much of any offroading, so the closest to dirt I get is dirt/gravel roads. Generally wax the chain every 300-500km, more frequently if I've been riding in bad conditions.
  • I've so far had to replace the chain & sprockets twice on my '05 V-Strom DL650 -- first at around 30,000KM, 2nd at the 66k KM mark (so about 36,000KM usage) -- the initial replacement was shortly after I bought the bike (had just over 23k KM on it) and the previous owner had left the bike in absolutely filthy condition, the chain especially.
  • I've cleaned & lubed it frequently since then, but will admit I've put off adjusting the chain a few too many times/for too long.
  • I am considering switching to a different chain wax product to see if chain life changes significantly -- obviously there are other factors to this, this is by no means a scientific test, but more a curiosity...
  • My new chain, installed today, is a D.I.D. Professional VX series -- so an X-Ring, 525 size.
How about you guys?
#326 ·
How about you guys?
I have used scottoiler automatic chain lubrication, for years. Honda CB1300S, 77,000kms chain and sprockets replaced. A major part of chain and sprocket wear, is the front, that little fellah is working it self a lot, compared to the rear. A front change if done on regular basis, ie, 2/3, without having to replace chain or rear sprocket. As for a mess, no bother, engine clean, spray on, hose off, all done.
#3 ·
I voted "other"
I use an automatic chain oiler (Tutoro with a Scottoiler applicator bracket and single tip) and feed my chain a 50/50 mix of 25W60 motor oil and 80W90 gear oil. That's not a "special blend" it's just stuff I have on hand.
This is on a new chain and sprockets. The chain etc that was on the bike when I got it had unknown mileage on it but were genuine parts. I don't know if it was THE original part, but the bike had about 50,000Km on it when I replaced the chain. The PO used tacky spray lube which I continued with until I put the oiler on.
My riding is 95% road and the rest is only dirt roads, not off road.
Personally I think it's the routine that gives the best results over the choice of product. Lubricating it "lightly and often" I consider better than "heavily and rarely". "Lightly and rarely" is just begging for trouble, and "heavily and often" is just going to make a nasty mess around your wheel and front sprocket. That's just my opinion of course.
#4 ·
99% paved road 1% unpaved. Year round, all weather.
Have used 90wt gear oil in the past. A couple of cans of wax. DuPont Teflon seems less messy, easy to use. Apply when I sense the need - approx. every other tank. Clean with kero. Get about 24k miles per chain. No idea if any of this matters much.
Thanks for the responses so far guys, keep them coming!
Note: I added a 4th item to my poll questions: What type/brand of chain are you using? Feel free to post your opinions on past/present chains and how you felt they lasted.
#7 ·
DID 525 currently in bling gold. OEM sprockets from bikebandit, the latest set stamped Sunstar.
#6 ·
Home made chain oiler. ATF as the fluid.
ATF because I live near the beach and do ride dirt roads now and then, the dirt modtly flings off using ATF.
50,000'ks on the chain and rear, and really neither are badly worn. Front was changed at 30,000k's, slightly hooked.
#8 ·
PJ-1 Blue Label for me....works great, and cleans off when I want it too. I used to use Super Clean....that title is an oxymoron!! It is impossible to clean that white gunk off after it's been on the chain for some time...:furious:
#10 · (Edited)
I have about 295,000 km or 183,000 miles on my two DL650's.
1) I use Wurth HHS 2000 (Called HHS 2K in some areas)
2) Lube with every tank of gas and after every ride in the rain. I never ever ever waste time cleaning the chain since it does absolutely nothing useful anyway and might harm the chain
3) Prior to the above routine I cleaned and lubed my first two chains on my 2006 DL650 as per the manual. This meant cleaning with Kerosene and lubing with chain oil at 1,000 km (620 miles).
First Chain (oem): 33,900 km 21,018 miles
Second Chain (DID X-RIng) 37,900 km 23,498 miles. Went bad on a trip and rode about 3,000km 2,000 miles after the chain showed the red dust of death
Third Chain (DID X-RIng): Lubed with HHS 2000 with every tank of gas and after every ride in the rain: Replaced at 74,845 km 46,404 miles. Still had life left but was heading on a long trip so decided to be safe.
Forth Chain (DID X-RIng): still on the 2006 which is sitting in my hanger. Has never been adjusted. Had at last fill-up 55,769 km or 34,577 miles. The bike is currently retired so probably won’t see much more for mileage.
On my 2012 DL650 I replaced the OEM Chain at 66,060 km or about 41,000 miles. I replaced it then (with a (DID X-RIng) because there were 2 chain events on bikes around me. My mechanic thought I was nuts since there appeared to be lots of life on it and it had never needed adjustment except when the front sprocket wore out. Prior to lubing with every tank of gas etc. I replaced sprockets when I replaced the chain the way most people advise. Once I switched to the Wurth I found that my chain and rear sprocket way outlasted the front sprocket. I have worn front sprockets to nothing between 55,200 km (34,200 miles) and 61,700 km 38250 miles. Rear sprockets I generally replace with the chain but might rethink that as they show very little wear when the chain is replaced.
4) The replacement chains were all DID X-Ring intended for street bikes. I know they changed the codes but haven't paid attention.
..Tom
#11 ·
Liquid Performance chain lube every couple hundred miles. OEM chain and rear sprocket. (11000 miles) Front sprocket from SV racing...don't recall make. ....generally recreational/fair weather riding.
#12 ·
informative thread, thank you for sharing.
i have a question to add:
do most lube when the chain is warm?
and if so, do you purposely warm the chain with a ride before you lube?
tia
be well.
rob
#16 ·
I generally lube right after I stop so the chain is warm but I don't lose sleep over it.
I wouldn't go out of my way to warm the chain but try and make sure it can sit a bit before ridimg off. Ie: I generally fill up shortly before getting home and when I get home I lube. On a long ride I would normally lube the chain when I get to the gas station then fill up so it can sit as long as possible. Again I don't lose sleep over it. I just lube a lot.
..Tom
#13 ·
I'm performing an experiment to see how long I can get a chain to last without lubing it in the tradition sense. Every 500 miles I simply wipe the chain down with a rag soaked in whatever I grab off the shelf. WD-40, Motor Oil, ATF. Whatever.
I ride a lot in the dirt so an overly wet chain attracts dirt like a magnet. On my street only bikes I've gotten 23k miles out of a chain. If I get half the life out of the chain or 75% out of it I'll consider that a win for not having to deal with the mess and cleaning out the counter sprocket cover when I change out the next chain.
Reactions: p3tr and Cloudrnnr
#14 ·
I am brand new to the Wee. It came with a Scottoiler (thus the other response) and I use the Scotoiler oil that came with the bike. When that oil os gone I will probably use ATF. I hope this helps
#15 ·
I am not a fan of the Dupont stuff, not convinced the dry lube is effective. I have been using the Original Bike Spirits lube and really like it so far, and there is zero fling. Have a new chain on, so cannot comment yet on longevity.
#18 ·
Thanks again for the responses so far folks.
A reminder, whenever possible please include the mileage (in KM or Mi) you've gotten out of your previous or current chains -- and if possible, any contributing factors to these numbers. This is one of the most important pieces of information I'm looking for in this thread, actually moreso than the products being used.
Also: For those of you using ScottOiler/similar auto-oiling systems, what do you think of them vs the manual lubing/waxing method? Are they messy? Expensive to maintain/refill? I've been thinking of trying it out; I've read that they're fantastic for keeping the chain lubed but can be quite messy.
#25 ·
I'm using a Tutoro and like it. How easy they are to refill depends on where you mount the unit and I expect most are the same in that regard.
I think there are distinct advantages over manual spray-can lubing, but they're not a set and forget forever thing either. You have to keep an eye on the applicator tips and tubing and watch for damage depending on how you mount things. You also have to set the feed rate to suit how and where you ride and how much mess you will tolerate. If you park your bike for extended periods you might be better off with one of the sticky lube sprays for long term rust protection. There's nothing stopping you from using both, and using the sticky spray right before you park the bike for winter might be a good idea.
As for cleaning I might wipe the chain down once in a while with an oily rag, but that's it. I'm against any scrubbing that might damage the o/x/z-rings.
#19 ·
Voted "Other"
I use most any dedicated chain lube, preferring the tacky, messy kind. I'm currently liking the Maxima Clear Chain lube.
I lube immediately after a ride, but don't warm it if it needs it now.
The last chain was on a ZX9 (138 rwhp) that when 34K miles. I don't bother cleaning them very often.
I always replace the set, both sprockets & chain all at once. This is the best way to get the most mileage from a chain. I like the DID brand.
Maybe it's anal, but I also "break in" the chain by riding easy for a hundred miles or so; not wanting to "shock" any one section until it's had some run time.
Works for me.
#20 ·
I used the DuPont Stuff until they changed their formula. Bought my bike w/ 10k on it and got another 15k outta the chain with DP. Not sure why it started to kink, probably just time. Now use Bel Ray. It performs great. 15k on it now. Clean (thoroghly w/ WD40) and lube every 500 - 600 miles. Have not had to adjust it but a few times.
#21 ·
1.) I still use the original DuPont Teflon Multi-Use Dry, Wax Lubricant as I stocked up before the formula changed. I ride mostly pavement but do some gravel and dirt roads. No trails or off road, at least not on purpose. Rain or shine but no snow or ice.
2.) When touring I lube every evening while the chain is still warm. Otherwise, about every 500 miles and I try to do that too when the chain is still warm. I do not clean the chain; stopped quite a few years ago.
3.) Last chain lasted 23,700 miles and probably had a little more life left in it but the front sprocket was showing signs of hooking and I had a 4,700 mile trip coming up. Stretch was in spec and no signs of kinking.
4.) Chain is a DID 525 ZVMX.
YMMV
#23 · (Edited)
other
I switched last fall to a 50/50 mix of 90wt gear oil/bar oil. I squeeze a few drops at a time on a little sponge on a stick (something I found in a drawer) and simply roll the chain past it. It is way less messy than sprays and I am finding there is actually less fling than lighter spray lubes. So far, the chain is staying clean by itself. It seems more slippery too than heavy gunk-like sprays. I will not be able to do this on trips though, because experience showed me the little bottle does not travel well. But good at home for daily riding. Can't verify, but I suspect a chain would last longer with the sponge application than spray, which can be spotty. I am liking it and it is quick. Only downside is (as of now) it's limited to my garage. For trips, I will revert to Maxima Chain Wax which worked well for me in the past. I clean with diesel a few times a season when using the wax mostly.
I have a DID X-ring with Superlight steel sprockets with about 9,000 miles on them. Not sure how long they ll go.
#24 ·
Use the dupont teflon dry lube (still available at Lowes in Canada, at least in greater Toronto area). Use the spray bottle after approximately every 400km (250 miles) when chain is warm and also after riding in the rain. Use the liquid bottle while traveling longer distances on a daily basis. Clean the chain with kerosene when it gets really dirty (after very dusty roads esp). 30,000km (18,000miles) and still on original chain and sprockets. Look fine.
#33 ·
If the blue can doesn't have Wax on the label, then it is the new, inadequate formula.
I use Schaeffer's #227 Moly Roller Chain Lube
"Schaeffer's Moly Roller Chain Lube combines the penetrating action of a superior quality penetrating oil with the lubricating ability of molybdenum disulfide - the most slippery substance known. The result is a chain lube that not only penetrates and lubricates, but also will not attract dust."
Schaeffer Oil | Moly Roller Chain Lube, Chain Lubricant
#27 ·
I think 80/90 gear oil should be included as it used to be recommended in some Honda (I think Honda) owners manuals. Please dont ask me to prove it but I am convinced they did and I used it. Bike stunk like gear oil all the time though!
#397 ·
That's what I've been using. A bit messy (OK... way to messy) but I've used it on all my chained bikes with great effect. I would like a less dirty alternative ... that doesn't leave my spokes and wheels quite so obviously dirty.
#30 ·
Motorex Road Strong
This lube seems to stick great and and lasts a long time between applications.
Very easy to clean off if you over lube.
Tested it against Belray Super Clean and Blue Tac. Moterex will be the one I will continue to use.
Super clean did not last very long and blue tac was messy and gummed up my clutch pushrod severely.
Hope this info helps someone.
Cheers,
Ray B.
#32 · (Edited)
Lately I've been using the Honda Pro chain lube which is a teflon/wax type. Works well, I like lighter lubes since I ride on dirt often. I do miss the DuPont dry teflon lube, the yellow motorcycle version they have now doesn't seem the same to me.
Mainly I'm looking for rust prevention and something that doesn't attract too much dirt. The Honda chain lube stays on and yet it's easy to wipe off during cleanings. On pavement the lube lasted over 1,000 miles with at least 4 rain showers I had to ride through. At 1300 miles its still fully coated, but the chain needed cleaning due to dirt build up on the plates, center rollers stayed clean. Pretty good stuff, better than the gooey chain wax IMO. I like many of the Honda lube/cleaning products and it actually cost less at my local bike dealer than a can of DuPont chain lube at Walmart... go figure.
#34 ·
Ride completely on the street, almost never in the rain. I try to warm up the chain first, good excuse to go for a ride. Used to use PJ-1 Black label. It was easy to apply but would sling all over the wheel, etc (previous motorcycle). The only lube I've used on the new Strom is Liquid Performance. I actually use it as a solvent to clean the chain first - spray on and wipe off right away with a rag until the chain is nice and shiny. Then go over it again to saturate the rollers and plates. Don't have a fixed interval but probably about every 400 miles or so. Will do it if I notice the chain getting especially noisy. Haven't gotten enough miles to wear through a chain yet.
