Chain riveting tool loan needed - Albuquerque NM - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
West and Southwest CA, AZ, NM, CO, HI, NV, UT
 20Likes
post #1 of 28 Old 01-24-2019, 11:11 PM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
Does anyone in the Albuquerque, NM area have a chain rivet tool I can borrow?
Thanks!
DesertBike is online now
post #2 of 28 Old 01-26-2019, 11:00 AM
dravnx's Avatar
The Stockton tool from Cycle Gear works well. I've changed 1/2 dozen chains with mine. I think I got it on sale for $29.99. If you own a chain drive, you need one.
Motor7 likes this.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is offline
post #3 of 28 Old 01-26-2019, 11:08 AM
PerazziMx14's Avatar
You can also get a screw type master link where all you need is a 10mm wrench. No more chain press or rivet tool needed and it permanent if you are the sort that doesn't trust clip type master links.
Simply tighten the nuts off until they snap (yes they are designed to snap off) off and you have a perfectly installed link.
notacop and NVDucati like this.
PerazziMx14 is offline
post #4 of 28 Old 01-26-2019, 11:46 AM
Highwayman2016's Avatar
I'm going to try that on my next chain.
2014 650 Strom
Highwayman2016 is offline
post #5 of 28 Old 01-26-2019, 01:53 PM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
Good idea. Wonder if it's OK to mix manufacturers? I ordered a DID chain, but they don't offer a screw-type master link. Only EK and BikeMaster, as far as I can tell.
I'm not keen on buying yet another special-use tool that I'll only need once every ~3 years, even if it's only 40 bucks or so.
post #6 of 28 Old 01-26-2019, 03:02 PM
Fox
Fox's Avatar
I love these, but you're not supposed to tighten the nuts until they snap. You're supposed to tighten them until they won't turn, back them off enough to check that the plate is on all the way, and then grab each with a plier and snap at the weak points of the studs.
Good video overview (recommend muting):
edit:
I wouldn't recommend mixing manufacturers. There is no guarantee of fit. Better to find a local friend who's willing to help you out, or pay a reputable shop to rivet the new chain.
I won't go back to non-screw type. It is so much easier, only a couple dollars more for the option, and gives me peace of mind.
Fox is offline
post #7 of 28 Old 01-26-2019, 08:08 PM
NVDucati's Avatar
Having the same gauge chain is more important than same brand. IMO
Member: AMA
NVDucati is offline
post #8 of 28 Old 01-27-2019, 07:39 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
Harbor freight will permanently loan you a chain breaker for $16.
https://www.harborfreight.com/heavy-...ker-66488.html
It's not the best, but it works.
Mulewright and Motor7 like this.
richlandrick is online now
post #9 of 28 Old 01-28-2019, 11:24 AM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
Someone local offered to let me borrow his, so I should be set. He has one of the nicer tool sets (Motion Pro) so we'll see how she goes.
post #10 of 28 Old 01-28-2019, 12:04 PM
I dug the catchy tune in the video. Makes me wanna use that type of link in my soon to be replaced chain!
I suppose at replacement time it's the same as other links? Simply grind off the bit sticking out and use a drift pin to push the link out the back side?
DesertBike likes this.
Chain and Sprocket Combinations, with EK Chain Breaker - Press Fit Rivet Tool SV Racing Parts SV Racing Parts 188 09-24-2017 02:34 PM
Chain and Sprocket Combinations with RK Chain and Press Fit Rivet Tool SV Racing Parts SV Racing Parts 104 07-14-2017 11:12 AM
Chain Installation On 2012 Glee Strom Tompkr DL650A - 2012-2016 0 04-01-2014 03:11 PM
Chain and Sprocket Combinations with RK Chain and Press Fit Rivet Tool SV Racing Parts SV Racing Parts 145 03-31-2014 05:18 PM
