Is this a bad idea? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
West and Southwest CA, AZ, NM, CO, HI, NV, UT
post #1 of 10 Old 05-30-2014, 08:47 PM Thread Starter
Is this a bad idea?
this august I am looking at riding from Georgia to Zion National Park. My plan is hitting AL,TN,KY,MO,KS,CO, then cut down thru the four cornres into NM, AZ, then up to Zion. I'm thinking of coming home by way of northern TX, then work my way back east somehow. Considering the August heat, what do you think of the plan?
[SIGPIC][/SIGPIC]2012 DL650 Adventure
troglobil is offline
post #2 of 10 Old 05-31-2014, 06:49 AM
Mastery's Avatar
Just use common sense. Take lots of breaks. Drink LOTS of water. Wet down your shirt and keep another layer over it. Use lots of sunscreen.
Lighten up, Francis. If you can't take some sarcasm, an Internet forum is the last place you should be.
http://www.JourneyLogbook.com - Easy to use adventure journals
Mastery is offline
post #3 of 10 Old 05-31-2014, 07:04 AM
Ditto to what Mastery posted
stromdog is offline
post #4 of 10 Old 05-31-2014, 08:37 AM Thread Starter
thats what I was hoping to hear.
post #5 of 10 Old 05-31-2014, 12:44 PM
You're from Georgia. Hopefully, your weather will have conditioned you for the heat. You will have to hydrate even when you don't feel it, because some of the time out west, you will not feel the perspiration like back home. But you will be losing water just the same.
06 V-Strom DL650
John V Strom, Jr. is offline
post #6 of 10 Old 05-31-2014, 03:52 PM
surlywill's Avatar
Heat wise you should be fine with lots of water breaks. You might want to stay in S Utah route wise. Canyon Lands, Arches, Bryce and Zion all worth seeing. Also Moab if you want more dirt, but it will be hotter...
2012 650 Adv
surlywill is offline
post #7 of 10 Old 05-31-2014, 06:05 PM
Base Camp's Avatar
Originally Posted by troglobil View Post
this august I am looking at riding from Georgia...... Considering the August heat, what do you think of the plan?
With you being from Georgia... the saying out west is ...."at least it's a dry heat"
August, is the monsoon/summer rain and thunderstorm season. Sounds like a fun trip.... post a "as your traveling" ride report, would enjoy reading and seeing your pictures
Base Camp is offline
post #8 of 10 Old 05-31-2014, 06:13 PM
ThatFixedIt's Avatar
I took a similar trip two years ago from Atlanta in July. I rigged an insulated gallon water jug to a camelback bite valve using ice maker supply tubing. Kept it full of ice water and sipped almost constantly in the heat. Used some of the water to drip into sleeves and collar to extend cooling time of wet shirt.
2015 DL1000
2012 BMW K1600GTL
2009 DL650 (Sold)
2009 Yamaha V-Star XVS950 (Sold)
All with the required enhancements.
ThatFixedIt is offline
post #9 of 10 Old 06-01-2014, 09:28 PM Thread Starter
Thanks for all the input. One more question.. Do those cooling vests work as they advertise out there? I know in Georiga with the high humidity they are not worth a flip.
post #10 of 10 Old 06-01-2014, 11:43 PM
Skin temperature in hot weather is about 95F. If the air is hotter than that, the air will heat your body. Too much ventilation raises the body temp. In the hot dry regions you want limited ventilation over an evaporative layer. The cooling garments work, but so does a sweatshirt that is kept damp, or a cotton shirt that is kept damp.
Drink water. Maybe some diluted fruit juice or diluted sports drink sometimes. Don't drink too much sugar. If you can't pee, you're dehydrated. You can crash due to dehydration, the way it makes the brain function. You can also crash due to excessive hydration...low sodium in the body.
What The Color of Your Urine Says About You (Infographic) — Health Hub from Cleveland Clinic
