Doc Wong's Dual Sport Clinic - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
West and Southwest CA, AZ, NM, CO, HI, NV, UT
post #1 of 8 Old 04-15-2014, 01:39 AM Thread Starter
Thanks to Tydive, I spent yesterday learning to handle my Wee better in the dirt at Doc Wong's Dual Sport Clinic. Forty-ish riders met up south of Hollister, CA, then headed out into the wilderness south of New Idria. We practiced dirt riding techniques in a small open area for a couple of hours, then put our skills to use riding the unmaintained roads through the hills of Clear Creek.
Technical notes:
- reducing tire pressures to 25psi does provide some better grip and bounce, but not enough (for me) to wheelie on the stock tires in dry, fine dirt
- pulling the 25A pump fuse does a perfect job of disabling the ABS
- the SW-Motech skid plate successfully deflected multiple large rock impacts, and survived at least one bottoming-out
I met two other V-stroms there. Someone new to the bike, and someone not new. Hopefully they'll pop in to say hello.
Attached picture is my Wee with some of the other bikes at a high point along our path.
hobbyist is offline
post #2 of 8 Old 04-15-2014, 02:28 AM
rubenz's Avatar
This sounds like an awesome event. I will have to get some more info and try to make it out to one of the clinics.
2006 DL650
Growing farkle list: Aux LED's on SW Motech Light Bar, Bark Busters, OEM Touring Screen, Bestem LED Top Case, Charging Port, DL1000 Seat, Madstad Bracket w/MP Cycles Windscreen, Pat Walsh Design Radar Shelf, Neslon Rigg CL-855 Luggage, Givi Engine Guards, Sargent seat.
Iron Butt Association Member - Qualified with 1,118 mile Saddlesore
rubenz is offline
post #3 of 8 Old 04-18-2014, 01:39 AM
That sounds amazing are those stock tires? no issues there? I'm apprehensive about getting into serious dirt with just the stock tires.
Hule is offline
post #4 of 8 Old 04-19-2014, 01:48 AM Thread Starter
Indeed, they are Trailwings. The definitely slid around a bit in the dust and boulders, but I never lost it or got stuck or anything. I was probably more careful in the downhill hairpins than I needed to be, if I would have been more comfortable with leaning the bike underneath me.
I did not do the mud section. The Doc insisted that anyone who wanted to attempt it have knobbies. Remembering what wet clay roads felt like in the Adirondacks at the NEVA13 camp out last year, I think that was wise.
We did get to do a few small water crossings (a few inches deep by a few feet to a couple yards wide), but they had hard (rock or cement) bottoms. Absolutely no trouble with traction I found.
If I were going to regularly do roads like what we saw or worse, I'd definitely look for more aggressive tires. But, for everything else, or for this sort of occasional ride with help at hand, the stock tires seem fine.
hobbyist is offline
post #5 of 8 Old 04-19-2014, 04:03 PM
Awesome. Thanks for the insight
Hule is offline
post #6 of 8 Old 05-06-2014, 09:28 AM
Tydive's Avatar
I'm happy to see you made the clinic.
I was scheduled to attend, but had a last minute change in plans. My Dad was there on his DRZ400 and really enjoyed the class.
We're going to be playing at Metcalf during the week. I got some K60 scouts put on last week and am looking forward to having decent dirt traction.
Hopefully I'll make the next Doc Wong dual sport clinic.
[URL="https://www.stromtrooper.com/ride-reports-route-sheets/211578-california-idaho-lolo-motorway-magruder.html"]California to Idaho Adventure style[/URL]
[URL=http://bayarearidersforum.com/forums/showthread.php?t=478959]Taking America by Strom 2015[/URL]
Timing is everything.
Tydive is offline
post #7 of 8 Old 05-18-2014, 09:57 AM
Hello Hobbyist,
That was a good experience in the clinic. To actually learn to lock up either tire (on purpose) and be ok with it. I definitely need more practice on the loose stuff to be more proficient.
Also need to upgrade with a skid plate that is compatible with the Hepco & Becker center stand and GIVI TN532 crash bars.
Interested in checking out some potential trails? We should do some planning.
The one thing I learned in the group clinic was to leave plenty of room for other riders ahead, to not get caught on a hill, behind a stalled rider(s).
Fly Guy is offline
post #8 of 8 Old 05-18-2014, 02:34 PM Thread Starter
I finally did my first oil change with the skid plate attached a couple of weeks ago. I undid the rear attachment bolts and swung the plate down, as suggested. With the bike on the side stand, I was able to slide my oil pan in just far enough that it caught everything from the drain plug. When removing the filter, I had to prop the pan up on the skid plate a bit to get underneath. So, no actual spills, but I was glad to have a pan that was over 2x larger in capacity than what I needed, to allow for some tipping.
Same here. It was easier to keep moving slowly than to find a place where I could stop and put my foot down suddenly, and not become stuck myself.
hobbyist is offline
