Oil Leak/Left Side/Countershaft sprocket area? anyone esle?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 09-13-2004, 12:09 AM
Johnny
It's a Well maintained 2002 DL1000 , 11K miles. The oil ends up dripping from the middle of the cases @ the split, and the trail seems to lead to the C/S Sprocket area....Ideas :roll: ? Thanks ! please respond to : [email protected] :lol:
post #2 of 5 Old 01-02-2006, 12:04 PM
nortoneer
johnny,
I'm having an oil leak around the countershaft area also. Did you confirm that you leak was the seal? It's leaking pretty badly, about a quart every 300 miles.
Dave
post #3 of 5 Old 01-05-2006, 06:44 AM
It could be one of two seals from that area, the countershaft seal which can leak as a result of a chain to tight or wear or the clutch slave cylinder pushrods seal which can leak due to an accumaltion of grunge around it under the countershaft sprocket cover.
The only way to find out which is to remove the c/s cover and inspect, not a difficult task but the clutch lever must be tied back against the lever with velcro or wire or a piece of string before removing the slave cylinder. Then it just a matter of a few bolts to check it out.
"Travel has no longer any charm for me. I have seen all the foreign countries I want to except heaven & hell & I have only a vague curiosity about one of those."
Twain
BradM is offline
post #4 of 5 Old 01-05-2006, 11:04 AM
oil leak
i'm in the process of replacing clutch slave cyl push rod seal now, buggered up the 1st seal and another is on order. i did not secure the clutch lever before removing, did i contribute to the problem? and do i need to secure said lever before reinstalling slave cyl? thanx, jet
'03 dl1000 yellow
oxford hot hands grips
mp3 with yes and cindy woolf
mpcycle shields
jet7271 is offline
post #5 of 5 Old 01-05-2006, 06:38 PM
I don't know. I do know that the manual requires the lever be held prior to removal to prevent issues, exactly what I haven't researched. I would be very cautious and look for more information before you do compress the lever without the system intact though.
Twain
BradM is offline
DID VM2 + 16T Front Sprocket + Stock Rear Sprocket GrayWolf Maintenance How-to 39 11-04-2011 11:36 PM
14 tooth front sprocket from SV Racing xjchad Product Reviews 4 08-17-2011 12:31 AM
2002 DL1000 Front Sprocket removal chazzei1 DL1000 from 2002-2012 1 05-24-2011 03:50 PM
17T Sprocket on wee rwsshooter V-Strom Modifications and Performance 2 07-25-2008 11:25 AM
Chain and sprocket tutorial Tollster V-Strom Service and Maintenance Questions and Discussions 3 05-12-2008 10:03 AM
