Clunky 1-2 shift - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 09-10-2004, 02:07 PM Thread Starter
Clunky 1-2 shift
I am a new 03 yellow strom owner. The bike is used with about 4k miles. The 1-2 shift is really "clunky". I read the manual and it recommends that I shift at 12 mph. Seem kinda low. Is this normal? Also, when I start the bike in gear, the bike lurches forward a little like the clutch is not fully dis-engaged. I had a 00 SV650 and it did the same thing. Is this normal or were both bikes in need of servicing?
ryan is offline
post #2 of 15 Old 09-10-2004, 03:03 PM
Bob
Your suspicion about the clutch not being full disengaged sounds right to me.
Bob
Bob is offline
post #3 of 15 Old 09-10-2004, 04:31 PM
Flyingyogi
Mine does the "lurching' too, but only when cold. Try it when the oil is hot, no more lurching. I suspect the clutch plates and the steel plates are closer together than other bikes, add some cold stiff oil and there is some friction. As for the clunk from 1-2, it is a big throw thru neutral and the gears are further apart. Physically and range wise. I just got used to it. My Yama makes noises that the VS doesn't and wise versa.
post #4 of 15 Old 09-10-2004, 07:24 PM
azsidewalker
Do you know what kind of oil it has in it? The oil may be the incorrect kind making the clutch sticky.
And as for the 12mph shift point, yes that seams real low. I shift around 4000-5000 rpm's under normal, no trafic, kind of conditions which is around 20-25 mph.
post #5 of 15 Old 09-11-2004, 04:32 AM
Wambo's Avatar
What kind of oil are you running? When I switched to synthetic the shifting really smoothed up-like the difference between night and day. Mine had some lurching at low rpms but after remaping the low end on the fuel injectors it has smoothed out.
'08 SYM HD200
'07 Suzuki Bandit 1250
'06 Ducati S2R
'04 DL 650 Black-sold
'05 Buell XB9sx-sold
'04 GSXR1000-sold
'06 Triumph Tiger-sold
'06 Triumph Truxton-sold
Wambo is offline
post #6 of 15 Old 09-11-2004, 10:04 AM
Randy B
I'll second that on the synthetic oil. I recently changed to it and it made quite a difference in the shifting. Much, much smoother now
post #7 of 15 Old 11-18-2004, 05:37 AM Thread Starter
Dont know about the oil. Has the same oil when purchased it. I'll try synthetic oil. The clutch is fully pressed and still lurches forward. The bike has been shipped overseas, hope I can get parts.
ryan is offline
post #8 of 15 Old 11-19-2004, 02:43 AM
GB #121
Depending on where you've shipped it, you should be ok pretty much anywhere overseas. Change your oil, but even then, when cold, she'll push against the brake (DL1000).
She just wants to go, that's all.
post #9 of 15 Old 11-20-2004, 04:38 PM
Woofy
I suggest investigating cluch adjustment also concerning the lurch you described.
And as much as I'd like to say that the quality of shifting is independent of the oil I use, my experience with the 'Strom and other bikes indicates otherwise. Synthetic oil seems to really make a difference in shifting, especially after a few thousand miles have been put on the odometer.
post #10 of 15 Old 11-21-2004, 10:05 AM
Pauljo
I've noticed the same thing. Synthetic blend (semi-synthetic) didn't make much different. But I put in full synthetic recently (7500 miles) and immediately noticed a big improvement. Shifting is now extremely smooth. But I still do get a bit of a lurch on that initial engagement of first gear when the temps are cold outside. I consider that normal. On a warmer day, or after the bike warms up a little, that disappears.
FactoryPro.com EVO Shift STAR Kit ??? hogsniper V-Strom Modifications and Performance 22 07-25-2014 07:12 PM
Help with shift lever - I knocked it out of straight alignment! robardin DL650A - 2012-2016 6 09-17-2012 10:55 AM
Is your 2nd gear shift clunky? austin03 DL1000 from 2002-2012 18 11-01-2010 05:35 PM
2006 DL1000 won't down shift!!!! TAH1 Maintenance, Tech and Products. 2 06-01-2010 09:21 PM
Can't find neutral/hard, clunky shift - DL650 gargantua V-Strom Service and Maintenance Questions and Discussions 11 08-06-2009 07:53 PM
