front wheel bearing failure 50 miles away.. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 03-17-2013, 08:22 AM Thread Starter
1FnStrom's Avatar
Last Sunday morning, with zero warning, my right side front wheel bearing disintegrated while exploring some new dirt roads over 50 miles from home (80k miles on the bearings). I pulled over and checked the wheel and that's when I noticed the bad wobble. With a wobbly front end, I drove 15mph home(2.5 hours) there was 4 ball bearings left...that's it. Just a bunch of metal shavings.I went to Applied Industrial Technology and picked up a set of SKF 6203-2rs. $25a a pair and are sealed on each side! A fraction of OEMs but much better quality. The left side bearing was in great shape but the other was trashed.....I wander why one disintegrated and the other side was in great shape.......?
04' Wee. ADVMOTOSTUFF bashplate, Suzuki handguards,Madstad,Anakee 2s, Givi crashbars,fender extender, 16t counter shaft, k&n filter,aluminium radiator &oil cooler guards, 1" bar risers, Garmin GPS, 12v accesory socket, Jessie panniers, voltmeter, MRA, and Saddleman saddle for my ass.
1FnStrom is offline
post #2 of 5 Old 03-17-2013, 08:35 AM
CanadianFZ6's Avatar
Well, glad it didn't leave you stranded... Maybe seal wasn't as good as the other bearing... ? Maybe the way it was greased (or lack thereof) at assembly?
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #3 of 5 Old 03-17-2013, 11:26 AM
One cause of failure can be if the spacer between the two bearings is the incorect length,which was a well known common fault with my model guzzi, factory installed. 030" to short spacer causing a side load on bearing after axle was titened resulting in eventual failer. Suzuki service manuel shows a spacerbetween front wheel bearings. when I replaced mine guzzi bearing I installed one side then measured the distance from that race to the other bearing seat and shimed the tube spacer to that length,after second bearing was installed the spacer had no play.
71 BSA Victor 500, 78 Yamaha XS750, 83 Yamaha Seca 550,
01 Triumph TT600, 98 MG Ev1100, 02 MG Lemans V11,14 kawi klx250s, all sold except 2012 Suzuki Dl1000
v2rider is offline
post #4 of 5 Old 03-17-2013, 11:45 AM
Scott E. Bonds's Avatar
Thats unusual for one to disintegrate with no warning. When was the last time you stuck your finger in them and spun the wheel to check them? Even a small gritty feeling is reason to change them out.
Having this happen at high speed could have been much worse.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
post #5 of 5 Old 03-17-2013, 12:10 PM
Exactly! The smallest noise or rough spot is the sign that they're dying.
The original seals are removable. One seal could have been out of place and allowed dirt and water to enter that bearing. The -2RS bearings used for replacement have two resilient seals (thus 2RS) on the sides and long life grease inside.
