I need clutch help - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 09-04-2004, 09:25 PM
Ty
I need clutch help
I have a 02, I changed the oil and didn't measure it out. I put a bit to much oil in and have since drained the excess. Now my clutch slips real bad. I only have 11,000 miles on it. Do you think running 30 miles or so with 1/2 qt. of extra oil would burn out my clutch plates? what should I start with??
post #2 of 4 Old 09-04-2004, 11:31 PM
Can't see that causing that problem.
2004 V-Strom 650
2002 GS500
2004 KLR250
2014 DRZ400
mike183 is offline
post #3 of 4 Old 09-06-2004, 09:18 AM
What kind of oil did you put in?
I am not sure what you used But
Many synthetics are too slippery and cause the clutch to just spin
rather than lock up.......
If you did that just drain it and put an oil in it that meets the proper standards for the bike.... (per the manual SF or SG, API Standard)
if you went away from that standard... could be your problem
No Problem.. it probably will not have hurt anything.. just drain and replace..
I have heard of this before on other bikes
Chris
04 DL-650
Have a good time, ALL the time !
Chris is offline
post #4 of 4 Old 09-06-2004, 10:47 PM
Ty
I need clutch help
the oil I used is honda line oil. SJ SAE 20-50 GN4. I don't think this oil would cause the clutch to slip. It gets worse as it warms up.
??? I guess I will bite the bullet and take it to the local shop. If anyone has any other suggestions I would rather fix it myself than take it to the shop.
Thanks
Ty
06 Wee Clutch Engagement Problem tetsuo69 DL650 and DL650A - 2004 to 2011 7 06-05-2015 11:04 AM
Need Clutch Help Strange Dog DL1000 from 2002-2012 12 03-25-2015 11:11 PM
I am sorry but, another frigging clutch question. carlrf DL1000 from 2002-2012 33 10-29-2014 10:01 AM
Extended clutch arm? SRTeric DL650 and DL650A - 2004 to 2011 1 09-02-2012 02:47 PM
Help, clutch won't disengage! mirage V-Strom Service and Maintenance Questions and Discussions 13 06-04-2008 10:22 PM
