Need help with first valve check and adjustment - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 03-09-2013, 08:53 AM Thread Starter
domromer's Avatar
I've never checked my own valves so this will be a first. Other than the usual tools. What specific items do I need to check and adjust the valves? I've got the shop manual as well. Any tips or tricks that I should know?
If all you ever do is all you've ever done, then all you'll ever get is all you ever got.
domromer is offline
post #2 of 7 Old 03-09-2013, 10:07 AM
2007 DL-650 Valve Check and Adjustment | Black Lab Adventures
Performed Valve Job w/many pictures for 650(warning 56k)
Are threads that supplement the manual nicely.
post #3 of 7 Old 03-09-2013, 08:43 PM Thread Starter
domromer's Avatar
Re: Need help with first valve check and adjustment
Thanks GW, this looks like it will be a help.
domromer is offline
post #4 of 7 Old 03-09-2013, 09:36 PM
The valve cover gaskets can be reused, but do take a close look as you replace the covers before you tighten the covers. The gaskets can slip out of place, not seal, and maybe get pinched and damaged. A close look will show them out of place if they slipped.
post #5 of 7 Old 03-10-2013, 10:03 PM
bwringer's Avatar
The procedure is a bit different if you have a DL1000.
I would suggest adding that information to your signature and your profile.
bwringer is offline
post #6 of 7 Old 03-10-2013, 10:08 PM
His profile says he has a 2007 DL650.
post #7 of 7 Old 03-10-2013, 10:13 PM
Also,
Be extremely careful when putting the valve covers back on. The aluminum that they screw into is made out of butter (Cam Journal Holder I believe?). I stripped one of mine using a $200 inch lbs torque wrench. They are a pain in the ass, and on top of that I had some problems with a helicoil repair. I eventually got it sorted out, but it pretty much ruined the satisfaction that I got out of adjusting the valves myself.
DL650K8ABS IBA# 35551
mcb2 is offline
