Aftermarket chain? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 08-23-2004, 01:27 PM
Midget King
Aftermarket chain?
Any suggestions on an aftermarket chain? Also, is the stock chain on an '03 an o-ring chain? How do I clean some rust off of the stock chain?
post #2 of 4 Old 08-25-2004, 12:45 PM
Hi MK. Yes, the stock chain is an "O" ring 525 chain. I understand some owners go to a 530 when it's time to replace the stock chain. That means changing the primary and rear sprockets. There are upgrade 525 chains that are stronger and better that the stock though. You'll have to shop around. My K4 1000 Strom only has 700 mi on it, so I haven't gotten into upgrade chains yet.
Navel jelly will get the rust off with an old toothbrush. After that, clean the chain with a Kerosene soaked clean shop rag. Let it dry about a half hour, then use a commercially available (spray on) synthetic "O" ring lube on the inside of the chain. It helps to tie a "twisty tie" around the outside of a link before you start so you know where you are on the chain. Let it all dry till it feels "matty" or "sticky" (doesn't take too long). Adjust the chain tension to the manual spec, and you're good to ride.
If you're a complete "newbie" to chain maintenance, you might get someone with experience to help you the first time. But definitely learn to do it yourself. It's a very important part of motorcycling.
I hope this helps you.
TL
"always follow your heart"
TommyLee53 is offline
post #3 of 4 Old 08-25-2004, 09:03 PM
Midget King
Thanks
Thanks
post #4 of 4 Old 08-27-2004, 10:51 AM
GB #121
Excellent recommendation. I tried that last time I cleaned/lubed the chain and it took all the guesswork out of it. Mind you, the wife is still hunting the twist tie from her mobile phone charger. Ooops.
Chain and Sprocket Combinations with RK Chain and Press Fit Rivet Tool SV Racing Parts SV Racing Parts 104 07-14-2017 11:12 AM
Chain Slack Rebel Trepidator Maintenance, Tech and Products. 37 03-06-2015 05:24 AM
Chain Installation On 2012 Glee Strom Tompkr DL650A - 2012-2016 0 04-01-2014 03:11 PM
Chain and Sprocket Combinations with RK Chain and Press Fit Rivet Tool SV Racing Parts SV Racing Parts 145 03-31-2014 05:18 PM
