Rear Shock Adj Knob - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 08-14-2004, 03:40 PM Thread Starter
Rear Shock Adj Knob
Hello,
Rear Shock Adjustment Knob..
The Hand Knob on my DL-650 was very hard when I first go it. It wouldnt budge
It seemed to be frozen in the all the way High position.. I gave it a good grip and a little muscle and I felt it go pop and un freeze itself.. Now it seems to work fine... Up and Down .. No Problem....
Good Ole Me.. Got to thinking in Preventatve maintenance mode..
"I Probably need to clean an lube behind that knob".. So I took the knob off
Sure enough, there's all kinds of Road Grime behind it.. I clean and then shoot some super Lube into the 4 holes on the valve mechanism..
I Notice 2 holes have Springs in them....
I put it all back together... everything works fine
Later I happen to see 2 Ball Bearings on the floor right there under the bike. Small Tiny ones....
My Question: Were those 2 balls in there.. On top of the holes that had the springs?
Anyone ever take their knob off and see these 2 bearings?
The DL 1000 Manual isnt detailed enough it just shows the shock removal.
My garage is a mees.. so those bearing might have been from something else BUT nothing I can remember messing with lately
Thanks
Chris
04 DL-650
Have a good time, ALL the time !
Chris is offline
post #2 of 7 Old 08-15-2004, 09:01 AM
rjking
Bearings..
Chris I think the two little ball bearings you found were in there. My DL 650 adjuster knob "feels" like it has spring detents in it which would be little springs behing ball bearings that push in and out of shallow detent holes as the adjuster knob is turned. I checked my service manual but it does not show that much detail about the preload adjuster but I am sure that it has the spring/ball detent system like I described.
RJK
post #3 of 7 Old 08-15-2004, 09:09 AM Thread Starter
RJ
Thanks..
I think your right.
Today I will take the knob off again and investigate.
It makes perfect sense. Why would it have two hole with springs.. those springs are there for a reason. (as you said Sping detent.bearing on top)
Later I am going over to a buddies house. he has a 1000
I'll look at his too
OK I Appreciate it ! Thanks!
It's Raining .... again :cry: :evil: :cry:
04 DL-650
Chris is offline
post #4 of 7 Old 08-15-2004, 06:07 PM Thread Starter
YES
With out a Doubt the bearings belong in there... They provide spring tension to the knob. There is a groove milled into the back of the knob nut.
When you turn the knob you may notice a very slight 'click' that is the bearings seating into the groove.. providing detent.
So... if you ever take off that knob..watch for the bearings..make sure you put them back in.
My V-Strom ROCKS
04 DL-650
Chris is offline
post #5 of 7 Old 08-17-2004, 06:53 PM
rear preload
So when you turn that wheel, how do you tell what setting you're at other than the feel of it when you ride down the road?
I haven't seen a marker/indicator of whether I'm at 3,1 or 5 on my rear adjustment wheel.
04 Blue DL650 with some add-ons
and scratches...
p7m8jg is offline
post #6 of 7 Old 08-18-2004, 12:49 AM
azsidewalker
On the shock you will see a coller above the spring with some rings around it. If 5 rings are seen then it is on the highest preload. No rings mean lowest. Here is a paste from the sevice manual on adjusting the rear shock:
post #7 of 7 Old 08-18-2004, 03:25 PM
Thanks Dave. Makes more sense now that I can find the adjusting marks! :roll:
and scratches...
p7m8jg is offline
Rear Shock Spring Replacement Oldad Suspension and Tire Tech 3 01-17-2018 12:26 PM
Need Shock Knob Bud Holly DL650A - 2012-2016 0 08-19-2017 01:42 PM
Rear Shock Bleeding? Nelsonmd DL1000 from 2002-2012 2 04-20-2016 07:59 PM
DL1000 rear shock on DL650? crosscountry General V-Strom Discussion 11 08-05-2014 06:42 PM
rear shock cover - found a custom solution SeattleStrom General V-Strom Discussion 7 06-04-2013 09:25 AM
