Different Exhaust Temp? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 08-12-2004, 12:34 PM
sum1else
I have a DL1000 K4 with about 600 miles on it.
When I start it from cold and hold my hand over the rear pipes the left pipe has hot exhaust coming out and the rear one has cold.
When it's warm and I do the same test the difference is not as noticable at first but I've found that the left still seems hotter (if I hold my hand there for 5 seconds it starts to become uncomfortable on the left side but no such problem on the right).
Is this normal? (possibly some trickery in the engine management system when idling) Or is it an indication of a problem? If so - how bad a problem?
Many Thanks!
John H.
post #2 of 6 Old 08-12-2004, 03:10 PM
I noticed the same thing only visually since it was early in the morning and around 50 degrees.
It appears that the pipes are connected together and that might be the cause of the imbalance.
I found a pic of the area at http://motorcycleinfo.calsci.com/VStrom1.html
Hope the pic xfers over... sorry if it doesn't.
DL1000 K3
Gunney is offline
post #3 of 6 Old 08-12-2004, 11:44 PM
yukon42
Actually Gunney, there is no inbalance in the exhaust system. All my V twin bikes have temperature variances as described. Don't know why, don't really care as it doesn't affect performance. I had discovered on another V twin bike that when the RPM was raised for a short period of time, the exhaust gasses were equally hot from both cylinders.
In short sum1else, nuthin wrong with your motor. Run it like you stole it and enjoy the hell out of it! Nuff said!
post #4 of 6 Old 08-13-2004, 07:09 PM
sum1else
Thanks - either way you look at it I don't have to worry about it.
Don't worry, be
post #5 of 6 Old 09-22-2004, 10:00 PM
neXus
Ouf, I thought I had a problem too.
I observed they same thing on mine, the left exaust is hotter
then the right one, on a cold start and idle.
post #6 of 6 Old 09-22-2004, 11:06 PM
Bob
I've also noticed I get white smoke out of the left exhaust (which indicates too lean a mixture) when the bike is cold. Once it warms up the exhaust smoke is normal on both sides.
Bob
Bob is offline
Thoughts on Delkevic exhaust for my 2012 DL650 mattski1 DL650A - 2012-2016 71 01-03-2019 05:24 PM
Exhaust Install Problems bandroidx DL650A - 2012-2016 15 07-12-2014 04:43 PM
M4 Exhaust Install AdamThe3rd DL650 and DL650A - 2004 to 2011 4 01-30-2012 05:29 PM
