Cluth at end of lever travel at 12,000 miles?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 08-01-2004, 11:32 PM
alladinzane
OK, still sorting out popping sound at take off, new chain goes on tomorrow. Really hope that solves it (I was told my chain was underlubed!)
Now I'm noticing the clutch lever requires virtually no movement to disengage the clutch. Not showing any signs of slippage (yet!)...
Should I be alarmed?
I hit the road Thursday for Sturgis, this would be a bad time to fry a clutch!
post #2 of 6 Old 08-02-2004, 07:31 AM
Onenutmak
is that way even if you adjust the adjustment? are you going to that metric bike rally?
post #3 of 6 Old 08-02-2004, 10:37 AM
alladinzane
Adjuster? The reach adjustment on the lever? How does that affect the travel of the lever?
Ummm... Not exactly A Metric event (unless you count the oddly Metric V-Rod).
post #4 of 6 Old 05-10-2005, 11:57 PM
alladinzane
Clutch lever movement getting worse
OK, it's been almost 10 months and nearly 10,000 miles, clutch is starting to disengage by just barely touching the lever.
Is this the DL's way of telling me I need a new clutch?
Is there a way to adjust this thing?
Thanks for the help!
post #5 of 6 Old 05-11-2005, 12:02 AM
Which DL are we talking about here? If you have a DL1000 you might want to try and bleeding the clutch. If you have the baby DL then the cable might need to be adjusted. I wouldn't think you would need a new clutch with only 12,000 miles showing on the ODO.
rider1951 is offline
post #6 of 6 Old 05-11-2005, 12:00 PM
alladinzane
DL Clutch adjustment issues
Bike is a DL1000 and the mileage is 10,000 in addition to the prior post (now coming up on 20,000).
If master cylinder needed to be bled, wouldn't the clutch have to go to the grip to activate? I have the opposite problem. I barely need to touch the lever to activate the clutch.
Is there an adjuster at the clutch?
excessive front brake lever travel: one solution dtalk Maintenance, Tech and Products. 54 06-26-2017 09:33 PM
Clutch Lever Travel undednubz General V-Strom Discussion 3 05-23-2013 12:33 AM
DL1000 Clutch Lever Removal/Replacement MightyShep Maintenance How-to 6 10-06-2010 11:03 PM
'Bama bound for Christmas 2mstone Ride Reports (Route Sheets) 10 01-07-2009 11:05 AM
