Bad knocking sound leaving the line - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 07-23-2004, 12:12 AM
alladinzane
OK, it's an 03 with 12,000 miles, always run great, has a slight chudder at the usual part of the power band. I commute 75 mile a day on it on one of the worst freeways in So Cal (91 from OC to Corona).
Late last week it started making this metallic popping sound, sorta like hitting the case with a ball peen hammer. Just does it as I leave a light. Sounds like it's coming from the rear of the bike, but I can't really tell. Seems to be getting worse.
I'm due to ride this thing to Sturgis in two weeks, so this is scaring the hell out of me.
Any suggestions?
DLDave
post #2 of 12 Old 07-23-2004, 07:42 AM
Chain is OK ?
I've had the same 'problem'. The knocking i head was the chain 'touching' the bike.
After adjusting the chain, it was ok.
Greetz, xlrider
V-SRI 766
xlrider is offline
post #3 of 12 Old 07-23-2004, 10:57 AM
alladinzane
Chain adjustment seems fine, although the chain is probably due for replacement.
post #4 of 12 Old 07-23-2004, 11:10 AM
senecagreen
in the manual it tells you how to measure the chain stretch. If it is at or past the limit replace the chain and sprockets before you go to Sturgis or you will probably regret it.
post #5 of 12 Old 07-23-2004, 11:15 AM
alladinzane
No worries there, new sprockets and chain will be here Tuesday.
Really hope that solves it.
post #6 of 12 Old 07-23-2004, 11:36 AM
Does it happen just two or three or maybe four times as you pull away? Mine, an '02 with 12,000 miles has recently started doing that. I know it isn't the chain in my case. It seems to be coming from the right side of the engine. It wouild be interesting to find out what it was.
RDJEff is offline
post #7 of 12 Old 07-23-2004, 11:53 AM
alladinzane
Yeh, it seems like it only does it a few times as you leave the line. Hard to say, though it's pretty subtle and the wind and motor noise could be masking it.
post #8 of 12 Old 07-23-2004, 04:44 PM
I can't hear mine do it if I'm riding with ear plugs in, which is almost always. I do make a lunch run most every day without them, and that is when I hear it. Maybe I should wear the plugs all the time, and pretend it isn't making any noise.....
RDJEff is offline
post #9 of 12 Old 07-27-2004, 11:40 PM
Stinez
Mine does it because I'm due for a chain.
I just did a 2800 mile trip with some tough dirt and the chain went from 1/2 of the spec range to well past it very fast. I'm actually glad I made it home as the adjustment is maxed out and the chain still has >2.5" of play.
The bike stays parked until I replace it and the sprockets. 12800 miles.
post #10 of 12 Old 07-27-2004, 11:52 PM
alladinzane
I suspect the chain as well (I seriously can't find anything else), although I have 12,000 on the original chain, it is not loose, has plenty of room on the axle adjusters and the sprocket teeth are not excessively worn. Makes it kinda hard to accept.
Sprocket Specialist is having "power outages" right now, so I'm hoping to see my new sprockets and chain some time this week.
Hopefully I'll swap this weekend and report back.
Either that, or I have to ride a Harley to Surgis.
does your V strom 1000 makes Clicking sound? Ennsync DL1000 from 2002-2012 10 01-26-2018 02:42 PM
Sound check NW Adventure Rider DL650 and DL650A - 2004 to 2011 10 07-31-2013 09:52 AM
knocking sound when idle kees3 V-Strom Service and Maintenance Questions and Discussions 3 07-03-2013 10:08 PM
High pitched sound question sman V-Strom Service and Maintenance Questions and Discussions 3 04-06-2008 11:09 AM
Cold start knocking sound?? KShow DL650 and DL650A - 2004 to 2011 8 12-28-2007 11:02 PM
