Tire Pressure ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-06-2004, 12:37 PM
wpennington
Tire Pressure ?
Min. tire pressure ?
My 2003 V-Strom still has the stock Bridgestone Trailwing 152 tires. The recommended pressure for a maximum load is:
Front. 110/80 R19M/C 59H = 36 psi
Rear. 150/71 R17M/C 69H = 41 psi
I got onto a "large chunky" crushed rock road and scared the hell out of myself. I'm about 180 pounds. What do you recommend for a minimum tire pressure to maximize traction in a situation like this?
Bill Pennington
post #2 of 6 Old 07-06-2004, 07:10 PM
azsidewalker
The service manual page 2.26 shows cold inflation tire PSI as:
..........solo riding.........Dual riding
Front.......36..................36
Rear........36..................41
Therefore you could savely go down to 36 if your riding solo.
post #3 of 6 Old 07-06-2004, 11:12 PM
bruhed
I routinely run 20-22lbs front and rear when doing long stretches of gravel. On my previous BMW GS, they specifically recommended pressures as low as 16lbs for off road. I assume by they meant slow going.
When doing the Dalton in Alaska and the Old Denaly Highway, I ran the 22 lb set up. Worked great. Didn;t travel much faster than 45-50 and it makes a large difference in stability compared to stock pressures used on the highway.
Of course, I carry a tire inflation device with me and air up before picking up speed on pavement.
Give it a try, you will find it makes off roading much more pleasurable.
post #4 of 6 Old 07-07-2004, 11:52 AM
Hhhhmmmm! I run 36/36 all the time. Ran across the Denali Highway, no problem. My commute includes 7 miles of gravel road each way. You get used to the way the bike squirms, and it becomes second nature. Sometimes the bike feels like it is rolling across a bunch of marbles that someone spilled on the road, but if you just ride through it, its no big deal.
RDJEff is offline
post #5 of 6 Old 07-08-2004, 11:40 AM
Another idea is to lose the death grip. Many handling problems can be cured by relaxing your grip on the bars. Try it sometime!
RDJEff is offline
post #6 of 6 Old 07-09-2004, 12:02 AM
wpennington
RDJeff: Thanks for the reminder. Once I got used to steel bridge gratings, (and we have a lot of them here in Seattle), I don't even think about them anymore.
THE Tire Thread MightyShep Suspension and Tire Tech 1012 08-17-2019 01:20 AM
Check your tire pressure before you ride. bobbyvstrom General V-Strom Discussion 73 01-21-2016 10:01 PM
Basic tire pressure question dudemang DL1000 from 2002-2012 11 09-18-2015 04:23 PM
FOBO BIKE Tire Pressure Monitoring System gunnels Techy World! GPS, Electronics, etc 15 08-30-2015 07:07 PM
Tire pressure with passenger Bernard101 DL1000A - 2014-2016 5 04-21-2014 12:19 PM
