Disapearing clutch fluid - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 06-19-2004, 09:46 PM Thread Starter
I am starting to loose clutch fluid and cant find a drop anywhere Iam assuming the slave is leaking into the motor anyone else had this?
Embrace each day with enthusiastic indifference
YLO-JKT is offline
post #2 of 3 Old 07-04-2004, 06:04 PM
fastfrank
Hi,
I've had exactly the same thing myself. I initially put it down to when i did my first bleed of the clutch system. I thought it dropped because some excess air may have been trapped and had now left the system. I topped it up but its still continuing to drop slowly.
As with yourself, there are now obvious fluid leaks and mine seems to run fine.
All i can assume the reasonng behind it is:
a) clutch plates are excessivley wearing
b) hoses are worn
Looking to P/X mine for a Aprilia Tuono in a couple of weeks so it'll be someone elses problem then :wink: .
post #3 of 3 Old 07-05-2004, 01:39 AM Thread Starter
found it
Going in for new slave and clutch cover because the brake fluid ate the paint. Thankfully with 3 days left on warranty
YLO-JKT is offline
Clutch adjustment and front spocket maintainance nikolas DL1000A - 2014-2016 50 01-31-2018 01:15 PM
Clutch sticks seems to be sticking / hanging Grimmer DL1000A - 2014-2016 10 10-29-2017 02:54 PM
Clutch fluid leak novaboy DL1000 from 2002-2012 8 09-03-2013 05:40 PM
dropped vstrom now fluid drip Arielb1 DL1000 from 2002-2012 12 06-19-2013 10:17 AM
