DL 650 Valve Maintenance Interval - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 06-15-2004, 04:32 PM Thread Starter
HI,
On a DL 650
How often do you adjust the Valves? :shock:
Thanks
Chris
04 DL-650
Have a good time, ALL the time !
Chris is offline
post #2 of 18 Old 06-15-2004, 06:42 PM
14,500
2004 V-Strom 650
2002 GS500
2004 KLR250
2014 DRZ400
mike183 is offline
post #3 of 18 Old 09-17-2005, 09:28 PM
rcacs's Avatar
In canada the manual states 24,000km. I just checked mine with 23,400km on it and the valves were all within spec.
I have been using synthetic oil as well.
cheers
rcacs is offline
post #4 of 18 Old 10-02-2005, 05:39 PM
fyr
fyr's Avatar
Hey rcacs,
Ive got 6k on my 650. I did the 1st service myself but didnt check the valves. I am running regular oil but may go synth.
Did you get your 1st service and valves checked?
Don't threaten me with a dead fish!
fyr is offline
post #5 of 18 Old 10-02-2005, 09:19 PM
rcacs's Avatar
I do all my own service and repair work. I have never taken it to a dealer, not even for the first check. I run synthetic 4-stroke oil and have put on 28,000 trouble free KM's so far this year.
There is absolutatly no need for the valves to be checked for at least 24,000km, and mine were all still within spec at that mileage.
I worked for suzuki many years ago, and have always ridden suzukis.
cheers
rick in manitoba
rcacs is offline
post #6 of 18 Old 10-02-2005, 10:47 PM
fyr
fyr's Avatar
Rick,
Cool. I try and do my own work when I can. I had an old Ninja 900 and wrenched nearly everything (young and lacking $). But since I bought the Dl new I was worried that if I didnt bring er in I may have screwed the warranty. When I found it wasnt the case I just changed the oil..
Love the bike!
Glen
fyr is offline
post #7 of 18 Old 10-03-2005, 02:05 PM
rcacs's Avatar
Providing you keep reciepts and records of your service work (oil, filters, etc) and the bike shows no sign of abuse, the warranty must be honored. "warranty checks" done by dealers are good if you have found a dealer you can trust. Often (very) you will get work done that is not required, and some will tell you that they must do the work or you have no warranty. This is incorrect.
The valves are a fair amount of work to adjust on the Wee, so its very nice that they dont require adjusting very often. Using synthetic oil should really help out with this.
cheers
rick in mb
rcacs is offline
post #8 of 18 Old 10-04-2005, 01:38 PM
Bobb_Todd
I did mine at 12k, 24k and again at about 50k [all kilometers].
They have always been in spec
post #9 of 18 Old 10-04-2005, 10:49 PM
rcacs's Avatar
exactally my point. unfortunatly there are dealers out there hosing guys with valve checks at low mileage.
cheers
rcacs is offline
post #10 of 18 Old 12-18-2005, 06:45 PM
echo's Avatar
Two of the valves on my 01 BMW F650 were out of spec (too tight) when I checked them at 600 miles. They arent scheduled to be checked until 6000 miles. Is it worth taking a chance (however slight) that the valves are set correctly at the factory? If they arent, theyll be like that for 15,000 miles or until you check them.
echo is offline
Valve clearance adjustment - should both valves on each cam be similar? autopilotone Maintenance, Tech and Products. 11 02-27-2015 03:21 AM
Maintenance Interval for Heavy Use superslomo V-Strom Service and Maintenance Questions and Discussions 4 05-21-2012 09:56 AM
Winter Maintenance, 2ndary adjustment, etc Bisbonian V-Strom Service and Maintenance Questions and Discussions 0 12-30-2008 11:19 AM
Valve Shim Spreadsheet here for download Tollster V-Strom Service and Maintenance Questions and Discussions 1 07-03-2008 01:19 PM
