Fork Preload Adjustment - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 06-08-2004, 04:27 PM Thread Starter
Adjusting the preload on the forks can damage the caps. The caps are made out of very soft aluminum. So I started by making a tool that would fit tightly into the slot. Then it came to me, if you raise the front wheel off the ground and unload the springs less force should be needed to turn the thread. What do you guys think. A centerstand is needed for this then prop the motor up until the wheel is off the ground.
Scooter
scooter is offline
post #2 of 2 Old 06-08-2004, 04:51 PM
dbl_aitch
I've got a fender washer that fits real well. Cheap, too. Handlebars are in the way, sorta... Unloading the front end seems to help.
Front fork preload ?? troop DL650A - 2017+ 20 06-23-2018 05:02 PM
Possible to adjust front suspension on a DL1000 K2? Halisko DL1000 from 2002-2012 10 08-09-2017 02:31 PM
Issues after replacing my front fork springs IPLIT Suspension and Tire Tech 13 09-19-2016 05:06 PM
Remote Preload Adjuster on Elka Jarlaxle28 General V-Strom Discussion 6 07-08-2013 03:17 PM
Elka Shock Group Buy update! SV Racing Parts General V-Strom Discussion 220 09-05-2009 07:09 PM
