Yes.. another backfire quessy - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 06-05-2004, 07:30 PM
fastfrank
Hi all,
My DL1000 currently has 6800miles on the clock and I'm noticing irratic running below 3000rpm and sometimes loud 'spit' noises when cruising at 2000rpm. I think the spitting noise is a backfire. My fuel is 95 unleaded octane (in the UK).
Is something out of tune or is the fuel injection bolloxed? I know its due a service at 7500miles.
Superb bike apart from that :P
Thanks in advance
Frank
post #2 of 11 Old 06-05-2004, 08:33 PM
Pauljo
Try dropping to a lower octane gasoline, and see if it stops doing that.
post #3 of 11 Old 06-06-2004, 05:39 AM
fastfrank
Hi,
95 octane is the lowest I can get and is which I'm using.
post #4 of 11 Old 03-29-2005, 09:21 AM
jonathan_laub's Avatar
VStrom 1000 Backfires
Just put first 100 miles on new 2005 DL1000 and it backfires between 2800 and 3400 rpm on level grade. Has anyone determined what causes this yet? I just filled up with Premium grade fuel and just made problem worse.
Is this a timing or mixture issue? The dealer seems to think mixture.
-=J
jonathan_laub is offline
post #5 of 11 Old 03-29-2005, 11:05 AM
sempervee's Avatar
Simple FIX - You should not be cruising at 2000 RPM. * Ever, Ever, Ever.
Thats your problem!
You are lugging the engine. Ride @ 3500 + RPM all the time.
Makes a world of difference when you ride it like it was meant to be. Best Response will be tween 4500 - 7500 RPM!
sempervee is offline
post #6 of 11 Old 03-29-2005, 11:47 AM
fastfrank
sold my V-Strom now.... moved to better things: Aprilia Tuono :lol:
post #7 of 11 Old 03-29-2005, 10:37 PM
Backfiring at 3000rpm
Just returned from the dealer. It was the mixture. Problem solved. They hooked their computer up and adjusted to run richer. They come preset to the absolute leanest mixture it'll take to run. She now runs smooth from take-off to crusing rpm's and this with a tank full of premium fuel too.
-=J
post #8 of 11 Old 03-29-2005, 10:53 PM
Compared To What?'s Avatar
Or at least Different "things"
Compared To What? is offline
post #9 of 11 Old 03-29-2005, 10:56 PM
StromTrooper.com Founder
Howboucha's Avatar
I have had some seat time on a Tuono. Okay for around town, but not for me. To freakin' spendy, but very exotic.
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
Howboucha is offline
post #10 of 11 Old 03-29-2005, 11:08 PM
Huh?
Thats your problem!
who said anything about cruising? even so, backfiring is not acceptable anywhere around the tach.
-=J
Uneven throttle / backfire / uneven idle Mid Atlantic Drifter DL1000 from 2002-2012 10 06-02-2016 06:01 AM
Backfire on DL1000 fixed by idle adjustment andy750k2 DL1000 from 2002-2012 50 04-21-2015 01:09 PM
Gunshot, or backfire? Dirt_Dad DL1000 from 2002-2012 27 09-07-2014 11:11 PM
Backfire Motorcycle Night 8/15 finja Northwest 13 09-28-2013 04:28 PM
Met you at the Backfire Moto meetup in June - Who are you? LowAndSilent Northwest 0 07-17-2010 03:01 PM
