getting the front sag right - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 06-02-2011, 02:16 AM Thread Starter
mudrat's Avatar
I've just checked my front suspension sag measurement using the "zip tie on the fork leg" method ( I have no friends) and with the preload adjuster wound right in the best I can get is a without rider sag measurement of 20mm and a rider sag measurement of 40mm.
my actual measurements were
full extension = 150mm
bike only = 130mm
rider = 110 mm
If my understanding is correct I'm just under on the WOR sag and on the upper limit for RS.
Do I need to reduce my spacer length or replace my springs. ?
currently using stock springs, I ride on and offroad and wiegh 100kg (220lb) (give or take:mrgreen kitted ready to ride.
"Travel by Gravel and double your map" - Wardy (Saturn5)
2012 KTM 990 ADV.
K8 WEE - My Mods Blog [url] https://www.stromtrooper.com/forums/showthread.php?t=50363 [/url]
mudrat is offline
post #2 of 7 Old 06-02-2011, 06:02 AM
dl1busa0's Avatar
yes muddy its time i found .95 sonic to be good 4 me i'm 85kilo just a little tall so i'm going to adjustable links not lowering links but +2 -2 so i can raise it when loaded for birdsville...the springs rose my sag by 22mm according to cable ties on both legs plus it used 20mm less travel when jumping on the brakes...good luck.. and my forks are 25mm thru the clamps at the moment..i have risers on...about 130 from soupys in the states i ordered the links today.,,greg
k2 litre
laser pipes,rack and bag,heated grips,
gsxr750 calipers,billet levers,billet mirrors,billet risers,
billet rego holder,tank protector,autocom,
custom rear rack,alloy rad and cooler guards,
mcs steering damper with custom mount,super brace,
tinted indicators,fettelled suspension and .95 springs , soupy's raising links,sheep skin,
k&n filter,tank bag,12v outlet,pick up spools,
cruise control and 80 odd stainless bolts
dl1busa0 is offline
post #3 of 7 Old 06-02-2011, 05:20 PM
bwringer's Avatar
Yes, you need new fork springs appropriate to your weight. Sonic also makes excellent straight rate fork springs:
SonicSprings.com
Actually, I think everyone has to upgrade their fork springs. I don't know if anyone has ever seen the 90 pound ballerina who apparently does the suspension testing for Suzuki. She's got to be getting close to retirement after 3-40 years of crappy stock suspension.
bwringer is offline
post #4 of 7 Old 06-02-2011, 11:54 PM
tkitna's Avatar
I changed my fork springs and havent been happy. I still think I need to add a little oil. Anyways, how many clicks are avaliable on the forks. The stock settings were at 5 and i'm at 6 now. Just curious. Maybe I need to go a few more.
[b]Member 037 of the Flat Black Club[/b]
tkitna is offline
post #5 of 7 Old 06-03-2011, 03:08 AM Thread Starter
mudrat's Avatar
thanx Greg, had a talk to Stubbsie (Bikecare) today and he suggested add another 10mm of preload
adjusters are currently would right in ie highest setting.
2012 KTM 990 ADV.
mudrat is offline
post #6 of 7 Old 06-29-2011, 05:45 AM Thread Starter
mudrat's Avatar
ok 0.90 sonics are fitted, static Sag is 27mm, Dymanic is 41mm
I think (from memory) sag for Strom should be
Static 25 - 30mm
Dynamic 35 - 45mm
am I on the right track here
(I ride on and off road )
2012 KTM 990 ADV.
mudrat is offline
post #7 of 7 Old 06-29-2011, 06:54 AM
p38arover's Avatar
Originally Posted by mudrat View Post
I have no friends
and I know why after having ridden with you!
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is offline
