Front Brake no Feel Right - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 05-12-2011, 11:04 PM Thread Starter
SquidWilly's Avatar
Question Front Brake no Feel Right
When I squeeze the front brake lever it does not compress smoothly, but binds a little, kinda of in the mid way compression. Seems to go back to normal after the bike is driven for awhile. Never used to be like that, but I have no frame of reference for what is normal. Learning as I go.
06 wee 15,000 miles, What do I check for?
Much obliged
SquidWilly is offline
post #2 of 6 Old 05-12-2011, 11:23 PM
Ruggybuggy's Avatar
Not normal. Should be a smooth, short stroke. Take the brake lever off and check for mud or dirt that's binding the lever up. Could be a defective master cylinder and much less likely could have a front caliper problem. If your not familiar how the brakes work take it in or get a service manual. Were talking brakes!
Some people are like Slinkies...... They're really good for nothing but still bring a smile to your face when you push them down a flight of stairs!
Ruggybuggy is offline
post #3 of 6 Old 05-13-2011, 01:55 AM
Much obliged
Pull the lever forward and put some grease on the point where the lever presses on the M/C plunger.
RowBust is offline
post #4 of 6 Old 05-13-2011, 10:41 AM
Pry the brake pads away from the discs all the way back into the calipers. This will give you a few full strokes of the lever and master cylinder to find and fix your problem whether it is lever or master cylinder. Start with the easy stuff, and start with cleaning and lubing as described above.
post #5 of 6 Old 05-13-2011, 11:19 AM
randyo's Avatar
sounds like a lack of maintenance issue
or you ride the same places I do ( I sometimes go thru a whole can of Brakleen after a winter ride)
first before you go lubing things, use some brake cleaner to flush out any gunk, lube the pivot bolt at the lever, then some lube along the caliper pins
hopefully you've caught it early enuf that you don't have to rebuild a sticky caliper
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #6 of 6 Old 05-13-2011, 02:24 PM
Heavy's Avatar
Brake pivot is #5, clutch pivot is #12. Clean with WD40, or similar, and use a small amount of grease to lube them.
DL1000K6
Heavy is offline
