Cylinder replating/big bore kits? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 28 Old 05-09-2011, 12:24 PM Thread Starter
knybanjo's Avatar
Concerning DL650s specifically.....
I did a couple of searches on this board that didn't turn up any results so I'll pose the question here.
What do YOU know that is available for the DL650?
I understand that the cylinders have some sort of plating, who would one send those to?
Are there any big bore kits available?
If so, who has them and in what sizes?
Can unplated SV bores be used on the DL?
Do you know of anyone that has done this?
Thank you for any info you may have on this subject.
..... putting the fun in dysfunctional.....
save $5 on SmugMug https://secure.smugmug.com/signup?Coupon=0E8WP3kJcvvbY
knybanjo is offline
post #2 of 28 Old 05-09-2011, 12:46 PM
Heavy's Avatar
Originally Posted by knybanjo View Post
...Are there any big bore kits available? ...
Best, easiest, most reliable, big bore option.
DL1000K6
Heavy is offline
post #3 of 28 Old 05-09-2011, 12:49 PM Thread Starter
knybanjo's Avatar
I'm not looking for smart ass comments, but thanks for playing.
knybanjo is offline
post #4 of 28 Old 05-09-2011, 12:51 PM
Don't have any info on big bore / plating kits. Why not just go with the Vee. Wouldn't buy in to the negative comments without giving it a try. :beatnik:
(posted after Heavy, but seems to be a valid point. Just trying to understand your thinking.)
06 DL1000
2007 Royal Star Tour Deluxe
Illinois is offline
post #5 of 28 Old 05-09-2011, 03:09 PM Thread Starter
knybanjo's Avatar
OK maybe you need more info.
I am NOT interested in turning a 650 into a litre bike.
I have a 650 that is racking up the miles now and I'd like to freshen up the top end within the next year.
Having heard that the cylinders are plated with some kind of special Suzuki plating I'm not sure what my options are.
Once again I am NOT interested in a 1000!
Any info on the options for a 650 rebuild will be greatly appreciated.
knybanjo is offline
post #6 of 28 Old 05-09-2011, 03:16 PM
RedBean25's Avatar
Yes, the cylinders in the DL650 are Nikasil plated and as far as I know there are not big-bore "kits" available for it.
2012 Triumph Tiger 800 Roadie, White
2007 DL650 Blue -- SOLD
Stromtrooper Offroad Club Member #22
Blue Strom Club Member #17
My Strom's Experience:
RedBean25 is offline
post #7 of 28 Old 05-09-2011, 03:20 PM
The 650 has iron liners. They can be bored and oversize pistons are even in the parts fiche. Whatever that SCEM coating is, it isn't applied directly to the aluminum if it is really there at all. SCEM isn't in the engine description any more either so it was probably always a mistake.
post #8 of 28 Old 05-09-2011, 03:48 PM
Blair, an SV650 racer, probably has the most info about uprating the engine. [email protected]
post #9 of 28 Old 05-09-2011, 03:53 PM
Good luck with your project. Keep us in the loop.
06 DL1000
Illinois is offline
post #10 of 28 Old 05-09-2011, 04:03 PM
BWC
Kinbanjo, it does seem the 650 uses steel liners and the 1000 uses the Suzuki SCEM process (Suzuki composite electro chemical material) Sounds similar to a Nikasil process for the hardened wear surface.
Blair would be a good start to find out if any kits are available. The SV650 seems to be a popular track/race bike.
Bernie 05-DL-1K
BWC is offline
