Clutch adjustment question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 05-08-2011, 12:06 AM Thread Starter
I went through the adjustment procedure for the clutch, but noticed that the adjustment screw and locknut assembly has a lot of "slop" in its housing. When pulling on the clutch handle, the assembly wobbles in the housing as it rotates. I don't think this is normal, but since I've never gone through this before, I thought I'd ask.
I tried to find an exploded drawing of that assembly, but haven't found it yet.
Any thoughts or advice?
hornetguy is offline
post #2 of 5 Old 05-08-2011, 12:43 AM
rtb
rtb's Avatar
That clutch screw assembly is pretty sloppy. I think it's normal.
rtb is offline
post #3 of 5 Old 05-08-2011, 01:22 AM
It's normal.
post #4 of 5 Old 05-08-2011, 04:14 AM Thread Starter
Good... thanks for the replies.
I was beginning to think I was going to have to replace a bushing, or something.
post #5 of 5 Old 05-08-2011, 05:02 AM
As above, don't panic about it, movement is normal.
FYI.
They do eventually wear out, what you'll find is that the engagement range of the clutch becomes a larger proportion of total lever travel. When that becomes a problem it will need changing. Probably somewhere north of 100,000km.
Peter
PeteW is offline
