Fullbore Adventure-Touring Tires - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 49 Old 05-07-2011, 02:39 PM Thread Starter
Fellow Traveller's Avatar
I saw a mention of these tires on the tire thread, but I think a lot of people will miss it if it's isolated to that thread.
I often ride off the pavement onto rough roads -- sometimes very rough -- on my DL1000. So for me, the quest for the perfect dual-sport tire -- good for a long haul on the highway, and good on dirt or rough roughs -- has continued unabated.
Just to get it out of the way, I can't make myself go the Continental TKC 80 route. Just seems like a long slab-riding stretch would vibrate you to jelly, and would wear down the tire more than is acceptable.
I pretty much decided by looks alone that the Heidenau K60 is as close to a 50% street/50% dirt tire as you can get. However, availability in the correct size and TREMENDOUS COST have prevented me from trying them.
Next in line for me was the Shinko 705 radial. Not because it was that close to the Heidenau tread pattern -- it's not, it's more street oriented than the Heidi, perhaps 75% street/25% dirt -- but because it looks far better than the stock Trailwings and is CHEAP. For cheap, I can lose some dirt capability.
I had decided to blow the dough for a K60 front ($150) and a 705 rear (about $90) when I came across the Fullbore Adventure-Touring radial tire.
Full Bore Tires - Adventure Touring
These tires cost the same as the Shinko 705's in V-Strom size, are made in the same factory as the Shinko 705's, but differ from the 705's in exactly the way I wanted -- the same way that makes the Heidenau K60 better than the 705. That is, the gaps between the tread blocks on the Fullbore Adventure-Touring tires are slightly wider than the 705 gaps.
This makes the Fullbores look more like a 70% street/30% dirt tire, perhaps even more capable in the dirt than that.
So I ordered a front and rear for my 1K. If anyone else takes the plunge -- or already has more experience with this tire -- please let us know. For my part, I'll be telling you what I think when I get some miles on these things.
Fellow Traveller is offline
post #2 of 49 Old 05-07-2011, 03:15 PM
nvr2old's Avatar
Not sure how you decided that the tread has a wider gap. From the photos and other info. it appears to be the same. They show no R in the sizing(150-70V 17), so my assumption is that they are coming from the original bias ply mold. The radials at Motorcycle Superstore run(F $73.99 R $83.99) and I couldn't find a price on the Full Bores.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #3 of 49 Old 05-07-2011, 04:55 PM Thread Starter
tread gap, price
The gap looked wider than the 705's in the photo, so I actually called the guy who owns the mold and the company, Peter Vatrano, who confirmed this.
Regardless of gap size, there more tread blocks for the surface area when compared to the 705's, and the larger the tread block, the less the performance on dirt. So I would prefer the Fullbores over the Shinko 705 on that basis alone.
Unless Fullbore is lying, which is inconceivable in this situation, the tires are definitely radials, as confirmed by their name and Fullbore. Also, note that their M41 tires are, by comparison, listed as bias. The tire code listed on their side shows only the V, which is the speed rating. Higher than the 705's by the way.
As for pricing, they are virtually identical to the Shinko's -- I got front and back tires for $170 out the door from Temecula Motor Sports (California). There's a list of distributors on the Fullbore website, but in most cases these are regional distributors, so you'll have to ask your local MC shop to hook up with them to get your tires.
post #4 of 49 Old 05-07-2011, 05:39 PM
Question
"Japanese engineered and precision manufactured to deliver top performance."
Does that mean they're made in Japan, or engineered there, and produced somewhere else? Like maybe China?
Cascade Wanderer is offline
post #5 of 49 Old 05-07-2011, 06:05 PM
swingset's Avatar
Send a message via Yahoo to swingset
If tread gap was the only basis for a well-performing dirt tire, your rationale would be perfect...but compound has a lot to do with that, plus the angle of the tread cut has some play in performance.
For the $$, the 705's front and back are actually really really nice all around tires, they're very good in loose stuff, I've hit quite a bit of mud in them and tractored through without much slip, nearly as good as a TKC80 did on my Vee, which blew my mind.
Never met a dog I didn't like, a machine I couldn't break, or a woman I couldn't tick off.
swingset is offline
post #6 of 49 Old 05-07-2011, 06:18 PM
The pictures of the Full Bore M-40 radial look exactly like the pictures of the Shinko 705 radial.
Shinko is a Japanese company that has their tires manufactured in Korea. Full Bore might be the same tires with another distribution organization.
FT, you might have made a good find. Pls keep us updated with the performance of the Full Bore tires.
post #7 of 49 Old 05-07-2011, 06:31 PM Thread Starter
Fullbores not same as Shinko 705s
First Swingset -- right, I'm saying rubber compound being equal, the closer the tread moves toward a knobby, the better in the dirt. And yes, a lot of people seem to like the Shinkos. I still think they're probably a great buy if you're trying to improve the dirt-worthiness over the stock Trailwings.
Cascade Wanderer -- They are made in S. Korea. The molds were spec'd by Fullbore and owned by them. Probably made for Fullbore by Shinko.
As for the Fullbore A-T's being the same as the Shink 705s, they are very similar but not the same. When I google a good "full length" photo of the 705s in Strom size, then compare with this photo of the Fullbore M40:
http://traxms.com/MT_083-RT411-p-Mot...0-M41-Adv.html
... there are more tread blocks on the Fullbore (14 versus 10 for the Shinko 705). Two things, however -- maybe I'm not looking at equivalent size tires. And on close inspection the gaps look the same width. I guess I'll have to wait until I take delivery and measure them. But if I'm right, I'll be getting smaller tread block size and bigger gaps (more like the K60s). So at worst I'll be getting more blocks with equally large gaps, which should translate into better dirt grip. If I'm wrong, what the heck, I still get the equivalent of the Shinkos at the same price. We'll see.
post #8 of 49 Old 05-08-2011, 07:15 AM
KevinP's Avatar
Actually, when I looked at the link the original poster gave I found that they are listed as radials, for instance Full Bore lists the tire as:
150/70V-17 M-40 Adventure Sport Radial
110/80V-19 M-40 Adventure Sport Radial
I will be curious if anyone can compare these to the Tourance (not exp) which seem to be a well reviewed similar tire. Personally they look more 50/50 than 70/30? From pics these are mild knobbies that probably give much better wear than fuller knobbies like TKC 80 or Karoo. Not to pick a fight over details, but after running a few sets of TKCs I'd consider them a true 70/30 tires which cannot match the off road grip to a 90/10 tire like the Pirelli MT21 (not available in V-strom sizes unfortunately). Further, no DOT knobbie, even the aggressive MT21, can match a pure dirt tire in mud or deep sand. In the world of dual-sports we must accept the best compromise for our specific and usually competing needs.
KevinP is offline
post #9 of 49 Old 05-08-2011, 08:51 AM
Back in the dirt days I went for meanest knobbies. Usually Yokohama super diggers which have every other center knob missing and it looked like a giant gear.
Then I started riding with an old enduro rider who used cheap trials tires. He went everywhere rocks, mud, water etc. I had the tiniest advantage with giant knobs over the bowling ball side rocks here in Connecticut. Other than that it made no difference. I would also believe if you were in gumbo mud that knobs wouldn't fill up as quickly.
So I concluded for myself that gap size is unimportant especially on road type dirt. I might be convinced that the number of edges on the ground is a help but not the missing rubber
richw is offline
post #10 of 49 Old 05-08-2011, 11:49 AM Thread Starter
gaps vs knobs
Richw makes a good point. The problem is language -- I used "more gap" in the original post to describe how the 705's might be improved if you kept the original tread block layout. I tried to clarify the description of an improved tire by saying "more like a knobby" is better on dirt in a later post.
Again, I think the (expensive) Heidenau K60 looks like the optimum 50% street/ 50% dirt tire:
tiger 800 xc tyre's
and
XtremeShack.com - Free Image Hosting by XtremeHardware-HEIDENAU K60 SCOUT.jpg
The newest version has a thin continuous center strip of rubber which should cut down on buzzing/vibration at speed on pavement.
