OOps,did I kill my K&N? also-Hiflofiltro air filter:does it require the OEM gasket? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 04-26-2011, 02:44 PM Thread Starter
Has anyone installed a hiflofiltro OEM replacement air filter? This is a high quality standard style replacement available through parts unlimited, for those who are not familiar with the brand.
I made the mistake of re-oiling my K&N filter with spray on oil intended to used on a foal filter- it does not run right now. I have a surging at small throttle openings that is very annoying- I am pretty sure the oil I used (looks just like K&N stuff when applied but is a gooey petrol based stuff) has caused reduced air flow and thrown my mixture off at low R's so.... I am thinking about just throwing a nice hiflo OEM replacement in and need to know if it requires the stock gasket/spacer
whipit is offline
post #2 of 4 Old 04-26-2011, 02:55 PM
enumclaw's Avatar
I would clean the K&N properly first, let it dry, re-oil and see how it goes. I doubt you damaged it permanently.
Rob
Ride every day, it's good for you.
07 650A | KLR250(x2) | KLR650 | DRZ400 | FJR
enumclaw is offline
post #3 of 4 Old 04-26-2011, 03:21 PM
Scott E. Bonds's Avatar
I hate to tell you this but your filter is ruined. Send me your K&N and I will dispose of it properly. I will send you back a slightly used OEM filter to get you back on the road.
I have done the same thing. Re clean the K&N with cleaner meant for the foam oil you used. Then start over again.
Scott E. Bonds is offline
post #4 of 4 Old 04-26-2011, 07:51 PM Thread Starter
Thanks, I will clean the K&N and oil it with the correct stuff. I was under the impression that the chemical solvents required to clean the foam filter oil out may trash my K&N....Ill let ya know
whipit is offline
