Clutch slipage - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 04-14-2011, 03:32 PM Thread Starter
Clutch slipage
Problems with clutch slipage, 65K new clutch basket 5 K ago. Checked fiber disk,all with in specs. Does not do it all the time,most of the time you can;t make it slip. Any ideals?
Blackrock charlie is offline
post #2 of 5 Old 04-14-2011, 03:56 PM
cbrxxcess's Avatar
Send a message via Yahoo to cbrxxcess
Since you replaced the basket I will assume it is a Dl 1000. I would pull the clutch slave cylinder and the front sprocket cover a d make everything is clean. I want to say I have read a post or two where the gunk was causing some binding under there. I would also inspect and replace the fluid, and inspect all the seals for leakage. That way you will flush any air in the lines if there is some.
Keep the Rubber Side Down.
Jim
Present Rides
1986 XR600R,1986 VF1000R,1999 CBR1100XX,2006 CRF450X,2007 DL1000 V-Strom
[IMG]http://i412.photobucket.com/albums/pp210/cbrxxcess/Motorcycles/North%20American%20V-Strom%20Rally%202009/Canadamap.jpg[/IMG][IMG]http://i412.photobucket.com/albums/pp210/cbrxxcess/North%20American%20V-Strom%20Rally%202010/VisitedStatesMap.jpg[/IMG]
cbrxxcess is offline
post #3 of 5 Old 04-14-2011, 05:28 PM
gryphon51's Avatar
Are you using Car Oil
with all those real good Viscosity additives and slippery stuff in it?
Motorcycle oils are made for wet clutches..... Car oil is not.
gryphon51 is offline
post #4 of 5 Old 04-14-2011, 08:49 PM Thread Starter
M/C oil
Only using M/C oil . I also flushed fluid & any air from system
post #5 of 5 Old 04-15-2011, 06:58 AM
Lesman's Avatar
Remove the slave and reinstall it. It happened to me last year. It makes no sense.
Good Luck,
Les
I own the Bestest Strom in the World!!!!!!!!!!!!!!!!!!!!!
Lesman is offline
