Brake calipers does not slide - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 03-06-2011, 03:48 PM Thread Starter
Post Brake calipers does not slide
I'm struggling a little to decide whether to try to fix my front brakes myself or hand them in to a garage to get them fixed. The front brake calipers does not slide as they should, with the effect that there is alwas a certain remaining brake after I have used it for braking. In fact, when putting the bike on the center stand and lifting the front wheel up, I CAN move it, but just, it does not spin, instead it stops directly. And I can see that the pads are not evenly weared down, on one side of the disc, they are thinner. So it has to be fixed before I can take my DL 650 for a ride again.
I have also just this morning ordered some EBC HH brake pads. When I talked to the stupid Suzuki garage here in France, they said they would only fit their standard ones, but after reading some of the discussions, I realised I should not let that stop me. So, how difficult is this?
Thanks for any advice
Johan
johanbackman is offline
post #2 of 13 Old 03-06-2011, 04:10 PM
ozart's Avatar
It's not hard to do. I take mine apart periodically and clean the pins. Mine have some slight corrosion and pitting also.
ozart is offline
post #3 of 13 Old 03-06-2011, 11:01 PM
jokermtb's Avatar
New pads will not fix this problem. The problem is the caliper. The strom uses brake calipers that slide on metal pins - it's cheap old-tech brake design, they were old when my 84 Kaw was new.... These pins eventually get worn, and as they do, they tend to get hung up on the wear areas - not retracting fully and dragging is a common problem when the caliper pins get worn or pitted - just like your bike. It's very gradual, but it seems like you've hit the wall on this one.
Inspect your calipers and assess how much the sliding surfaces on the pins have worn. Might only need a bit of cleaning off, a bit of emery cloth/sandpaper polishing, to work well again.
jokermtb is offline
post #4 of 13 Old 03-07-2011, 06:06 AM Thread Starter
Well, I got that the pads has nothing to do with this. I just bought them because I wanted to change them while doing the work on the calipers.
So if I interpret you right, the design is made to wear the pins instead of the calipers.
So if the pins are bad, and I don't get it to work again, I can replace the pins and will avoid having new calipers ? (which I assume would be quite expensive)
Johan
post #5 of 13 Old 03-07-2011, 08:24 AM
Besides being clean, the pins should be lightly greased with hi-temp silicone brake grease.
post #6 of 13 Old 03-07-2011, 08:44 AM
Living the Stereotype
Stromin'Nroman's Avatar
Listen to this man. The stuff is available at any auto parts store. Don't use any other kind of grease, don't ask how I know.
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #7 of 13 Old 03-07-2011, 05:36 PM Thread Starter
Exclamation Bleeding problem
Ok, Now I've done it and managed to get everything apart (with the help from a garage to actually drill the caliper and then hammer out the bolts that keep the brake pads in place, they were in fact so stuck that we both questioned if we were doing the right thing...)
And I also managed to get everything cleaned and put in place again, with some proper grease and new oil and everything. So far so well. Only the bleeding to do.
And I did really try, but I did not in the end manage to get all the air out. Have now searched but could not find a good "how to". A few questions arise:
1. When I bleed the front brakes, should I have the lid of the brake fluid container on or off? I have read people writing about seeing bubbles coming up through the container...
2. I have not hose to connect to the bleeding valve, but when I pump up a pressure and the losen the valve, the fluid comes directly, no single indication of air or anything. It should not be a problem. But, is there any specific order for doing this? Right or left first? Both at the same time?
3. I read about the master cylinder. Is there another bleeding valve for that one, in addition to the ones on the calipers?
4. Have I missed something?
I really appreciate help on this.
Johan
...who has managed to shift piston on his sons motocross, but hits the ground hard when trying to bleed the brakes of the v-strom...
post #8 of 13 Old 03-08-2011, 12:59 AM
larolco's Avatar
Yes - you need to add fluid as it depletes. Bubbles good. You want them out.
Right/left first does not matter. Squeeze the lever, break open the bleeder. Close bleeder, release lever. Repeat until there are no signs of air. Tapping the calipers, hose, master cylinder with a wrench or the like can help the air move out.
No. But some air will rise through the master cylinder as you bleed the system.
Nope.
Johan
DRZ400SK17
larolco is offline
post #9 of 13 Old 03-08-2011, 05:48 AM Thread Starter
OK, many thanks, I will give it another try tonight.
post #10 of 13 Old 03-08-2011, 06:33 PM
Johan
Don't know what bolts you were drilling and hammering, but on the front calipers all that you need to do is remove the the clip from the pin, slide it out and remove the pads.
RowBust is offline
