Electrosport and Excel Stators - Buyer Beware!!! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 02-28-2011, 05:37 PM Thread Starter
Buyer beware on Electrosport and Excel brand stators for the DL1000. The Excel appears to simply be a re-branded Electrosport stator. Neither works.
Background:
On my way home to Atlanta from Florida, my charging system stopped working. Limped home, stator tested bad - one of the fields was open.
Ordered an Electrosport stator, trying to save some money. Installed new stator, new r/r, new battery. Bike wouldn't charge - performed all tests as specified by the service manual, everything checked out. Finally determined that the Stator isn't producing enough output to actually charge the bike - only way it will charge is with headlights disconnected, 14.5v that way. Connect one bulb, drop to 13.2 volts, connect the other headlight, down to 12.5ish volts, barely above battery charge.
Tested with 2 different batteries, and 2 different r/r's.
Ordered Excel stator to replace faulty Electrosport. Got it in the mail today, opened the box... and it's the same type of stator, with a different name on the box. Installed on the bike, and exact same behavior. Removed, and it will be returned.
I'm very annoyed by this; nothing more frustrating than junk parts straight out of the box. I've since googled on Electrosport, and see that I should never have given them a chance. I will be ordering the Suzuki part tomorrow.
Pics attached below.
06Strom is offline
post #2 of 8 Old 02-28-2011, 05:58 PM
SCraig's Avatar
Your report seems to go along with most other experiences I've seen pertaining to those parts. Yet another hard lesson learned.
Scott Craig - Nashville, TN
SCraig is offline
post #3 of 8 Old 02-28-2011, 08:07 PM
dtalk's Avatar
Those things are notorious.
dtalk is offline
post #4 of 8 Old 02-28-2011, 08:28 PM
randyo's Avatar
but they give you and "industry leading one year warranty"
I wonder.... if electrosport stators would do better with a mosfet rr rather than the oem rr
has anyone tried that combo ?
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #5 of 8 Old 02-28-2011, 10:11 PM Thread Starter
That was one of the two r/r's I've tried it on. The stock one, and the Shindengen. Same results on both.
06Strom is offline
post #6 of 8 Old 03-10-2011, 01:22 PM
longgreensilverado's Avatar
electrosport and Rick's stators are very bad products. nothing beats good old oem
I can't believe i forgot the trophy girls names.
2007 fast blue dl650
longgreensilverado is offline
post #7 of 8 Old 10-24-2011, 09:31 PM Thread Starter
Since I never followed up on this one, I did get a Suzuki stator, and used the mosfet r/r from Roadster cycles. Worked like a champ, should have done it from the start.
I did eventually get my money back for the two stators that were bad out of the box.
06Strom is offline
post #8 of 8 Old 10-25-2011, 09:05 AM
question
Was the blue coating tape or goo of somekind
I would think that some/all of these problems are the insulation braking down
Would taking the OEM and then give the coils a couple of coats of epoxy help extend the life
or?
http://store.eurtonelectric.com/moto...ostmodels.aspx
richw is offline
