brake pads options ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 02-25-2011, 12:26 AM Thread Starter
I'll need to replace my brakes pads early in the season if not done before getting my Vee out.
What are your suggestion of pads ? I've seen that EBC make organic and also sintered pads. Galfer seem to make pads too. I can go OEM but aftermarket is usually better.
Flat4awd is offline
post #2 of 3 Old 02-25-2011, 01:05 AM
K1W1's Avatar
I've just put Galfer ones on mine. They weren't expensive and the feel is way better but I did put Galfer ss lines on at the same time so how much is pads and how much is the lines I don't know.
K1W1 is offline
post #3 of 3 Old 02-25-2011, 01:24 AM
If you ride off road, go the EBC organics.
The EBC HH pads will give you stronger brakes, but they behave worse when when wet or covered in dirt.
Pete
PeteW is offline
