clutch not working - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 02-24-2011, 11:07 PM Thread Starter
clutch not working
Pulled clutch in feels to easy started bike in neutral clutch in put in gear bike takes off. any advise vstrom 1ooo 2002
lrgoldsmith is offline
post #2 of 9 Old 02-25-2011, 12:47 AM
10-95's Avatar
More info.
Fluid in clutch m/c? Any leaks? Hose ok?
10-95 is offline
post #3 of 9 Old 02-25-2011, 07:55 AM Thread Starter
no fluid
no fluid will fill it up and check for a leak.
post #4 of 9 Old 02-25-2011, 12:37 PM
larolco's Avatar
Your slave cylinder seal is likely toast. Common issue.
DRZ400SK17
larolco is offline
post #5 of 9 Old 02-25-2011, 01:04 PM
jokermtb's Avatar
Slaves are so unreliable, these days...........
jokermtb is offline
post #6 of 9 Old 02-25-2011, 03:38 PM
Start by taking the cover off the sprocket & clutch area and clean everything. Next, take a very good look. Report on what you see, what's moving & what should be moving but isn't, where any wet spots are.
post #7 of 9 Old 03-05-2011, 08:17 AM
mikefryman's Avatar
Clutch oops.
I had the sticky clutch handle and almost did not make it home. Clean the sprocket area.
Mike
mikefryman is offline
post #8 of 9 Old 03-05-2011, 06:58 PM
How many miles since you were in this maintenance area?
Bzar is offline
post #9 of 9 Old 03-08-2011, 12:40 AM
larolco's Avatar
I doubt that little bit of crud was the culprit.
Mine's way worse than that after a only a week of winter riding. Slush and salt and sand are the slave's worst enemy.
Mike
DRZ400SK17
larolco is offline
