Joint Separation - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By kenneth_moore
  • 1 Post By greywolf
post #1 of 7 Old 02-24-2011, 04:31 PM Thread Starter
kenneth_moore's Avatar
Joint Separation
There is a seam that runs along the top of the instrument panel, where the plastic that forms the "dashboard" and fork/handlebar opening trim meets the front cowling. It's right behind the windscreen.
Mine is opening up. The gap was minor at first, but now there's a gap big enough to push a card through. Cosmetically it's not good, but I'm more concerned about excessive amounts of water getting in to the backside of the guages. I'd like to get it tight again.
The only connection I can see for that plastic is the two snap 'n pops at the tips of the cowling, on the "inside." Can the panels be moved around in relation to each other if I dismantle the cowling, or is it just a symptom of the plastic giving way to 4 years of heat?
Thanks!
ryandono likes this.
Go hakafugu yourself.
kenneth_moore is offline
post #2 of 7 Old 02-24-2011, 04:43 PM
There are also two plastic spear into rubber grommet connections inside. #14 shows a grommet. It's like the connection of the side cowlings to the parts directly above them. Your parts are probably warped.
post #3 of 7 Old 02-24-2011, 05:39 PM
Mine is doing the same thing.
Now might be a good time to fix it, with winter and all.
2007 V Strom 1000
2002 GSXR 750/1000 streetfighter
1988 Honda ZB50
Cunningham is offline
post #4 of 7 Old 02-25-2011, 11:30 AM Thread Starter
Thanks GW.
Is parts replacement the only remedy, or do you think the spears can be heated and moved?
post #5 of 7 Old 02-25-2011, 11:34 AM
I can't imagine a good remedy for warpage other than replacement.
post #6 of 7 Old 02-25-2011, 05:24 PM
Nova Scotia Strommer's Avatar
I had the same thing thing happen to my dash after installing the Givi windshield. I made a dash shelf and installed it.It hides the crack and gives me a place to mount my video cam.
If you replace the dash it may just happen again.
What do you have for a windshield? Apparently the Givi shield can cause the dash to melt if the sun hits it just right from the back side.
09 DL650 ABS ORANGE "Form over function at a superior price"
09 DR650 "Hooliganizer"
03 TW200 "No Roads....No Problem"
02 TW200 "Redneck Edition"
Nova Scotia Strommer is offline
post #7 of 7 Old 01-16-2016, 09:22 PM
ryandono's Avatar
Redneck Remedy
I have the same problem. I know it's not the best remedy, but I used black electrical tape and covered the gap. I know the screen prevents most moisture from coming in, but I'm hoping the tape will protect it when the wind is blowing the rain in from the back of the bike.
Ryandono
2009 Suzuki V-Strom DL650 ABS
2006 Kawasaki Eliminator BN125 (20152016)
ryandono is offline
