Flat tire after filling with air - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 02-15-2011, 05:45 PM Thread Starter
bikefree's Avatar
I went to fill the tires and my battery operated gauge stopped working. I stopped at the grocery store for about 20 minutes, then another 3 miles later, I was almost home and the tire was flat. I don't see anything sticking out of the tire.
Could this be caused by over inflation?
2012 DL650 Adventure
bikefree is offline
post #2 of 9 Old 02-15-2011, 06:11 PM
redbike72
Just a wild guess but it might be something stuck in the valve. Air lines are sometimes open to contaminants and they could possibly get caught in the valve.... Perhaps closer inspection of the tire and valve might be warranted.
post #3 of 9 Old 02-15-2011, 07:43 PM
JerseyStrom's Avatar
stem
Check the valve stem, it could be loose or damaged. An inexpensive valve stem tool can be had at an automotive parts store.
09 DL650 - fender extender, Genmar risers, Madstad w/givi screen, oem handguards, corbin seat, ML lowering pegs, Givi crashbars, SW Motech skidplate, HT hiway pegs, Givi 532 racks w/ E21's, Amotostuff adjustable topcase rack w/ Givi V46.
JerseyStrom is offline
post #4 of 9 Old 02-15-2011, 08:07 PM Thread Starter
bikefree's Avatar
Thanks, Great info about the valve stem. I am guessing that this below is the culprit. I had them on both tires when I bought the bike and never removed them. This thing is supposed to tell you when you are low on air but probably slowly let the air out.
bikefree is offline
post #5 of 9 Old 02-15-2011, 10:21 PM
ozart's Avatar
Maybe, but I've run mine at 50 psi several times with no adverse effects.
ozart is offline
post #6 of 9 Old 02-16-2011, 10:00 AM
Heavy's Avatar
Cold temps can cause condensation in the air lines to freeze, sticking the valve open.
DL1000K6
Heavy is offline
post #7 of 9 Old 02-16-2011, 03:20 PM
Reinflate the tire and spray it with soapy water. Look very closely for small bubbles forming anywhere on the tire, valve, bead, and around the rim (cracked rim?). If there aren't any bubbles and the pressure holds, great, you had a problem with the valve. If it is the valve, try a new core.
post #8 of 9 Old 02-16-2011, 03:47 PM
zorlac's Avatar
Yeah, but he used thin air, leaks out faster.
zorlac is offline
post #9 of 9 Old 02-16-2011, 07:43 PM Thread Starter
bikefree's Avatar
Re-inflated, sprayed with soapy water, saw no bubbles, took it for a ride. Looks like I'm good to go.
Thanks for all the help.
bikefree is offline
